Old 09-03-2017, 06:05 PM   #1
Cody_1948
Cody_1948's Avatar
Default compression,Fuel and Spark but no start 226?
Guys, Ken and i where trying to get my F1 back up and running today with no luck. I have compression and spark and fuel. But all it wants to do is A not start or will back fire alittle. We set the distributor so it was facing Cyd 1 and also made sure #1 was top dead center. Ive set it like this last summer and had no problems with it not wanting to start up. I have brand new 6v battery new battery cables and good ground from motor to the frame. Anyone have any clues ?
Thanks
Cody_1948 is offline   Reply With Quote
Old 09-03-2017, 06:20 PM   #2
Vintage Copper 47
Vintage Copper 47's Avatar
Default Re: compression,Fuel and Spark but no start 226?
Thanks
H model engine?
WALT
"Old enough for the experience & too young to know better"
Vintage Copper 47 is offline   Reply With Quote
Old 09-03-2017, 06:31 PM   #3
koates
Hi there, #1 cylinder on top dead center on the compression stroke (both inlet and exhaust valves closed) and rotor pointing to #1 plug lead in dist cap. Dist points just opened before TDC. Condensers can cause trouble so fit a substitute for a try. Regards, Kevin.
koates is offline   Reply With Quote
Old 09-03-2017, 06:50 PM   #4
Capt Kirk
Capt Kirk's Avatar
A little background as to the history or what led up to this would be helpful. Was the engine running last month and now it's refusing to start after sitting?? Is this a new engine to you and you're just trying to get it running?? The events that led you to where you are now will be helpful.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 09-04-2017, 07:29 AM   #5
toby
toby's Avatar
Put in a good condenser. Happened to me on my 226 H. The condenser wire was partially broken inside.
toby is offline   Reply With Quote
Old 09-27-2017, 02:48 PM   #6
Heavy Duty
I had the same problem. New coil,condenser,spark plugs,you name it. Sent dist. to bubba and starts right up, like a new car.
Heavy Duty is offline   Reply With Quote
