Old 08-17-2017, 12:34 PM   #1
hb32
hb32's Avatar
Default Shift knob removal tricks.
I am trying, without any luck, to remove the original shift knob on a 32 stick to use it on a 40`s style stick without destroying either.
hb32 is offline   Reply With Quote
Old 08-17-2017, 12:57 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Shift knob removal tricks.
Use a strap wrench.
Old 08-17-2017, 01:44 PM   #3
DavidG
DavidG's Avatar
Or a pipe wrench with a strip of rubber to protect the knob. The threads are the normal right hand variety.
Old 08-17-2017, 02:08 PM   #4
Bruce Lancaster
Klein makes a small strap wrench of some sort of fabric covered with soft, almost sticky rubber-like stuff. VERY grippy and kind to surfaces.
Old 08-17-2017, 04:45 PM   #5
svm99
I've unthreaded some stubborn knobs by wrapping with course grit emery cloth and then using a small pipe wrench to unthread the knob after soaking with Kroil penetrant for a few days. Usually works for me. Paul J.
....just don't let the emery cloth slip.
svm99 is offline   Reply With Quote
Old 08-17-2017, 06:26 PM   #6
hb32
hb32's Avatar
Thanks for all the tips. I have been soaking it in Kroil as well and will try a pipe wrench with some rubber or suitable material.
Old 08-17-2017, 11:10 PM   #7
hb32
hb32's Avatar
Success !!
Rubber and a pipe wrench did the job.
Thanks
Old 08-18-2017, 12:18 AM   #8
Lawson Cox
Lawson Cox's Avatar
Good job.
Old 08-18-2017, 07:11 AM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
Originally Posted by hb32 View Post
Success !!
Thanks
Glad to hear you got that shift knob off. Maybe someone had used Loctite on those threads in the past to keep it tight. It seems like the shift knobs on my cars are constantly coming loose .
John
Old 08-18-2017, 10:45 AM   #10
corvette8n
corvette8n's Avatar
I ended up using epoxy to keep mine tight, pity the guy that needs to take it off in the future, hopefully it's not me.
