Old 08-12-2017, 09:17 AM   #81
zippi
zippi's Avatar
Default Re: Death wobble
Ok....got the wishbone ball to pop down. The rubber ball is whole so I don't see a problem. Re-installed everything and put cotter pins in.
zippi is offline   Reply With Quote
Old 08-12-2017, 12:37 PM   #82
hardtimes
hardtimes's Avatar
Good progress !
When you finish this job and test, let us know it you solved your original problem.
Worth mentioning again:
Check steering box attachment for TIGHT and adjustment !
Check pitman arm for THGHT !
Old 08-12-2017, 08:02 PM   #83
zippi
zippi's Avatar
Went to a cruise-in today that was about 25 miles away. We drove on the highway and plenty of side roads with bumps, patches, and a few holes and no wobble. Of course this means nothing as I could have gotten lucky today. Only time will tell.
Old 08-12-2017, 08:52 PM   #84
JSeery
JSeery's Avatar
The ball being loose sure could have been a contributor.
Old 08-12-2017, 08:58 PM   #85
V8COOPMAN
V8COOPMAN's Avatar
Don't you have a couple of CASTELLATED nuts? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-13-2017, 10:06 AM   #86
zippi
zippi's Avatar
No castle nuts. The cotter pins were tight going in. Better than the way it was with no cotter pins. Should be alright. I'll keep an eye on it.
Old 08-13-2017, 10:18 AM   #87
zippi
zippi's Avatar
Pitman arm feels tight. Not sure what steering box I have or where to adjust it.
Old 08-13-2017, 10:22 AM   #88
zippi
zippi's Avatar
Pic 2
Old 08-13-2017, 10:23 AM   #89
zippi
zippi's Avatar
Pic 3
