Old 07-24-2017, 09:58 AM   #1
Crestliner
Crestliner's Avatar
Default Are these 32 B ?
Believe these to be 32B and 33-34C.
Any help?
Dad always told me, A man is no better than his word!
Crestliner is offline   Reply With Quote
Old 07-24-2017, 10:24 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Are these 32 B ?
Not 32-34 4 cyl pump.Look at EBAY # 222591434627.That is the 32-34 4 cyl pump.
Old 07-24-2017, 02:37 PM   #3
DavidG
DavidG's Avatar
As Sheldon indicates, it is not OEM Model B, but the attachment bolt pattern and operating arm are similar depending on the dimensions. What is sort of weird about the pump are the multiple inlets and outlets, including one that would be nearly up against the side of a B block.
Old 07-24-2017, 02:56 PM   #4
Bruce Lancaster
I've encountered one (and only one, so far) type of ersatz Model B pump. It is not that one, it has only an internal filter and no removable cover on the rocker housing, but is fairly common. After cruising Hershey looking for matches I concluded that it was very likely from a six-cylinder flathead Dodge or Plymouth. It had 1/8 pipe inlet and outlet, each fitted with a brass adapter to take the Ford line nuts. I assume the rocker was replaced with a Ford one, but had nothing along to compare so perhaps the Mopar one was compatible.
The conversion is always the same and the sellers know that it is for a B, though no one labels it as a conversion...so I think it was a commercial offering marketed and cataloged as a B replacement. There's no way of telling whether the sellers actually know that these are not authentic, but they clearly know that B pumps have gotten pricey!
Old 07-24-2017, 03:04 PM   #5
Seth Swoboda
Seth Swoboda's Avatar
Any help?
Hello Max,
I can't answer your fuel pump question but I started the tear down on the '40 Ford engine we bought from you. The cylinders are standard size. I won't have crank out until this weekend. So far, unless there is a crack issue, it seems to be a good rebuild candidate. I hope you are doing well.
Seth
Old 07-24-2017, 06:24 PM   #6
37 Cab
37 Cab's Avatar
Says AC on it. GM possibly??
Tommy
37 Cab is offline   Reply With Quote
Old 07-24-2017, 06:28 PM   #7
Crestliner
Crestliner's Avatar
AC made pumps for other than GM vehicles.
Old 07-24-2017, 08:08 PM   #8
DavidG
DavidG's Avatar
Many, but not all production '32 B and V8 fuel pumps were made by AC.
