Old 06-19-2017, 04:47 PM   #21
JSeery
JSeery's Avatar
Default Re: 8BA Lifters?
There may be a rebuild date stamped somewhere on the intake mounting surface or a tag attached to the block somewhere that gives the rebuild date.
Old 06-19-2017, 07:47 PM   #22
leon bee
Okay. Did any 8BAs come with adjustable lifters? I did a google search and I've now read over 300 pages of old posts, but haven't figured this one out yet.
leon bee is offline   Reply With Quote
Old 06-19-2017, 08:16 PM   #23
JSeery
JSeery's Avatar
No, Ford did not install adjustable lifters. Are they the sold lifters or the hollow ones?
Old 06-19-2017, 09:04 PM   #24
leon bee
Thanks JSeery. I was tired and didn't study them. They have an oblong hole running kinda diagonally down the side. Been trying to figure out if this engines been apart previously, so I guess it has. Everything else seems original, but I'm a motorcycle guy mostly.
Old 06-19-2017, 09:29 PM   #25
JSeery
JSeery's Avatar
I guess I could be wrong, but I have never heard or seen of adjustable lifters in an original factory engine. Can you post a photo of the lifter?
Old 06-19-2017, 10:08 PM   #26
leon bee
I will, yes. Don't get to my shop every day. I'm eager to check the bottom of them like y'all said. I wasn't really having any reason to think the engine was completely original, just hadn't seen any sign of anyone being in there.
Old 06-20-2017, 10:34 PM   #27
leon bee
So I looked at my adjustable lifters today, the 8 I have out of the block. They are hollow, with three oblong diagonal slots on each. They look good. But, they are dead flat on the bottom.....nice and polished. Straight edge shows them dead flat, set them on my heavy saw table they don't rock at all.
And this is NOT good, correct? And I might needs be making other plans for lifters? Thanks to all you not tired of advising me about my lifters!
Old 06-20-2017, 11:39 PM   #28
40 Deluxe
This has been discussed here before. As I recall, at least some flathead lifters were flat on the bottom from the factory, so yours may be OK.
Old 06-20-2017, 11:58 PM   #29
JSeery
JSeery's Avatar
Double post
Old 06-20-2017, 11:59 PM   #30
JSeery
JSeery's Avatar
"So I looked at my adjustable lifters today, the 8 I have out of the block. They are hollow, with three oblong diagonal slots on each. They look good. But, they are dead flat on the bottom.....nice and polished. Straight edge shows them dead flat, set them on my heavy saw table they don't rock at all."
Sounds like a Johnson Lifter.
Old 06-26-2017, 02:12 AM   #31
leon bee
Old 06-26-2017, 02:16 AM   #32
leon bee
Having a little trouble getting the pics on here. Here's how all mine look, shiny and dead flat on the bottom. I ain't one to throw things away, do I need new ones? Thanks!
Edit: My next picture is of the bottom, but can't seem to get it on here. I'll try tomorrow.
Old 06-26-2017, 07:03 AM   #33
oldford2
oldford2's Avatar
Did ford install adjustable lifters in their 4 cylinder tractor engines?
oldford2 is offline   Reply With Quote
Old 06-26-2017, 07:12 AM   #34
chap52
chap52's Avatar
Go back and search for threads on this site dealing with adjustable lifters. You will find pictures of the holes that you will want to drill to make the adjusting easier. I would not plan on just using those cute little adjustable lifter adjustment tools to keep the lifter from turning when you try to adjust them. I have snapped the little tabs off of them.
I will try to find you a photo.
You will find great information on the "how to" of the process.
Old 06-26-2017, 07:16 AM   #35
chap52
chap52's Avatar
Here is the post I was referring to:
https://fordbarn.com/forum/showthrea...ustable+lifter
Old 06-26-2017, 07:19 AM   #36
tubman
tubman's Avatar
I'm sure you are aware that there are many firms that will re-surface your lifters (Egge is just one example). It would be a shame to lose a set of original Johnson's.
Old 06-26-2017, 12:16 PM   #37
leon bee
Tub: Don't be sure I'm aware of ANYthing on these engines.
Chap: Thanks a lot. I've now reviewed over 400 pages of old posts, but hadn't seen that yet.
Thanks to everybody.
