My 1950 F1 came to me without brake lines. The brass block on the master cylinder where the stop light switch goes has 3 openings. Where do the right, left & rear lines go in this block? Thanks you
It should be the same as my 48, one in rear is stop light switch, Rt side for Lind feeding rear brakes and left side to feed front brakes. Hope this helps
