Old 03-25-2017, 12:07 PM   #61
bruce lee
Default Re: Isky 404A cam - Harley Davidson grind?
Oops I guess I should of looked harder at the pictures. I see a jerk.
bruce lee is offline   Reply With Quote
Old 03-25-2017, 12:13 PM   #62
Jason in TX
Jason in TX's Avatar
The front snout area is full of oil with a seal on the nose where the pulley is and inside on the front of the two shafts before getting into the rotor area. The back originally had seals on the two shafts, shins and greased bearings but you can put sealed bearings in them now, and keep the old look. I read one article that someone removed the grease zero side of the sealed bearings so you could grease them but the grease not go out the other side.
The gears on the rotor shafts are drilled and pinned. You have to time the rotors or they will interfere with each other.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 04-17-2024, 04:28 AM   #63
naughtt
Resurrecting this thread in the hope of a bit more info. I’m in England but recently acquired an Isky 404a cam, new old stock together with the relevant double springs, lifters, staples ect. ( no jig but can make that). My engine is a French block running 4 1/4 crank, 3 3/8 pistons and currently a 400 jr cam. All running in a belly tank that only gets to play on Pendine sands and will do a bit of drags. It’s full race.
My question if any one can help is are the double springs worth using, what spring pressure is best, and advice on grinding each tip on the lifters and what to set it at cold?
If I were to have my Johnson adjustable lifters ground would they need re hardening?
Thanks in advance guys,
Brett.
naughtt is offline   Reply With Quote
Old 04-17-2024, 07:33 AM   #64
Bored&Stroked
Bored&Stroked's Avatar
I've checked the double springs against the Isky 185-G springs and the 185-G springs are actually better. I have no idea as to why Ed created the dual-spring package . . . other than to claim it was better and as part of the overall marketing of the 404-A. You should be fine with about 80 lbs on the seat - which is easy to obtain with the 185-G springs. I'm running 185-G springs on my flathead roller cam with 100 lbs on the seat (and heavy roller lifters) - have had the engine over 6200 RPM and never floated a valve . . . and my intakes are 1.72". For a full-on race engine, you might consider light titanium valves anyway (that is what I'd do).
Old 04-17-2024, 10:15 AM   #65
Shoebox
Shoebox's Avatar
Originally Posted by Newc View Post
Hi all; I see a Power Master starter there. They engage front to back, the opposite of a Ford stocker. So the ring gear bevel is for the stock type stater. Does the ring gear need to be flipped or rebeveled for the Power Master type?? Newc
I'm hoping to see an answer on this too as I have the same (uninstalled ) starter. Thanks.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is online now   Reply With Quote
Old 04-17-2024, 01:31 PM   #66
Pete
Brett.
Adjustable, so called Johnson lifters may need re-heat treating, depending on when and where they were made. This should be done in an inert gas atmosphere to eliminate any scale.
You will have to run the Isky radius lifters with the 404A cam.
You NEVER grind the lifter to adjust the clearance.
If you do not have a valve stem grinding attachment on your valve grinder, They can be machined very easily in a lathe.
Listen to Bored & Stroked on the spring info.
Old 04-17-2024, 09:14 PM   #67
cadillac512
cadillac512's Avatar
No, the PM starter gear has a bevel that lets it work with the ring gear as-is.
Now back to camshaft discussion.....
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 04-18-2024, 01:20 AM   #68
naughtt
Thanks for the input and advice so far guys.
Appreciate it.
Old 04-22-2024, 07:29 PM   #69
panic
The 1929-73 Harley-Davidson 4-cam flathead engines: small engine VINs are D, R, W, G, K & X, big engines are V & U (750, 900, 1200 & 1300cc)
The 1936-2000 single-cam pushrod OHV engines: a.k.a. knucklehead, pan head, shovelhead E & F (1000, 1200, 1340cc)
panic is offline   Reply With Quote
Old 04-22-2024, 07:45 PM   #70
panic
I have found that the low CR of the KR race engines required very strange cam events.
A sample:
Intake duration 310°
Opens 65° BTDC
Closes 65° ABDC
Intake CL 90° ATDC
The exhausts are all 30° smaller
The early closing point keeps the CCP and low speed torque up
When do hot Ford cams close the intake?
Old 05-02-2024, 11:23 AM   #71
panic
THOSE REQUESTING A COPY OF MY POTVIN CAM SPREAD SHEET: i NEED YOUIR EMAIL ADDRESS.
THANKS.
Old 05-03-2024, 09:54 AM   #72
KiWinUS
KiWinUS's Avatar
Thanks.
Old 05-03-2024, 08:16 PM   #73
panic
It appears that some performance cams for the Ford have fairly late intake valve closure ABDC. IMHO this is done for a good compromise between torque and peak power.
Engines with relatively low static CR may gain some torque by advancing the cam 4°.
