Old 03-15-2017, 08:14 PM   #1
Art Newland
Art Newland's Avatar
Default Strange filler cap on Master Cylinder
Picked up a new master cylinder for my 49 F-1. The filler cap isn't anything like the old one. Look familiar? Do I just have the wrong one?
Art Newland is offline   Reply With Quote
Old 03-15-2017, 09:19 PM   #2
alanwoodieman
Default Re: Strange filler cap on Master Cylinder
looks like some one added a fill plug on top of the fill plug--possible to help in bleeding the brakes? one on left is like the old original ones not the plastic one
Old 03-15-2017, 09:26 PM   #3
deuce_roadster
deuce_roadster's Avatar
I think that plug is removed for pressure bleeding.
Old 03-15-2017, 09:32 PM   #4
G32
The master cylinder is used on certain model forklifts --and has a cap
with a remote fill fiting -- tube from an upper reservor down to
master cylinder cap. My understanding.
Gene Tulsa
G32 is offline   Reply With Quote
Old 03-16-2017, 12:04 AM   #5
Art Newland
Hmmm, that's just strange. Maybe I can just take that cap off and use the old one?
Old 03-16-2017, 01:28 AM   #6
mike42
mike42's Avatar
Art .........
Very glad you asked this question, as I too bought a MastCyl at Napa and I have the same cap ! The cap on old original was exactly the same as yours in second picture. I left it alone and didn't use the old cap and all is well.
It would be interesting to find out what that is all about.
Thx...... Mike
mike42 is offline   Reply With Quote
Old 03-16-2017, 06:31 AM   #7
Kerk
I have a remote fill cap with a piece of tubing attached. I will never use it and got it with some other stuff. kx
Kerk is offline   Reply With Quote
Old 03-16-2017, 08:08 AM   #8
Tom/SC
Tom/SC's Avatar
The last three (different Fords) master cylinders that I have bought are made in this fashion. The first one the cap was so tight That we had to really struggle( strong arm) to get the cap to unscrew. Wagner box, but made overseas thank you! Tom Byrd
Tom/SC is offline   Reply With Quote
Old 03-16-2017, 08:40 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
Whatever cap you use make sure that the vent is open
Old 03-16-2017, 10:03 AM   #10
Art Newland
I found this on Mac's website. Listed as "Wagner Brake". Is it just a different manufacturer?
http://www.macsautoparts.com/ford_tr...s-made-f1.html
Old 03-16-2017, 10:15 AM   #11
Art Newland
Just tried to remove the entire cap... wow-wee it's on there tight! The little hex shaped bolt/plug comes right out. I added some fluid through the small opening and got it pumping. Sure doesn't seem to hold much brake fluid however...
Old 03-16-2017, 10:27 AM   #12
RalphG
RalphG's Avatar
I found from experience that those old caps will twist off if they have been stuck for years. I needed a new master cylinder anyway.
RalphG is offline   Reply With Quote
Old 03-16-2017, 12:58 PM   #13
Kube
Super Moderator
Kube's Avatar
Neither is correct. The "new" one is typical of what is now being installed. It works but is wrong. Your "old" one works too but also is wrong.
For those that might care, my attached photograph depicts a proper cap.
Old 03-18-2017, 09:08 PM   #14
Art Newland
It may be wrong. but was handy. I cut down a cheap funnel and threaded it in the center plug hole. Made bleeding the brakes a lot easier.
