Old 03-11-2017, 11:27 AM   #1
Lenny51
Lenny51's Avatar
Default Steering box adjustment
My steering wheel on my 51 has a lot of play in it I turned the top adjustment in . There is a plate underneath that you can turn looking
from the bottom of the car do I turn it clockwise or counter clockwise
& how much do I turn it .
I am getting a new idler arm kit from Chris , the king pins are tight &
the rest of the linkage feels tight . The wheel bearings have a little
play but I cant go to the next cotter pin hole
Thank you for any help on this
Lenny51 is offline   Reply With Quote
Old 03-11-2017, 11:32 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Steering box adjustment
I think this adjustment is made with the car jacked up so there is no weight on the front wheels.
Double check to be sure.
Old 03-11-2017, 12:56 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
The top screw is what adjusts the sector play. This is done with the steering wheel centered and is screwed in to tighten. The bottom is most likely the same as the top (screw in to tighten).
Just a hint, after adjusting the sector shaft play, if you feel a resistance while turning the steering wheel either right or left of center, this could indicate a worn worm gear
Old 03-11-2017, 01:15 PM   #4
JSeery
JSeery's Avatar
However, there is more to it than just tightening the screw clockwise. You need the pitman arm remove (best) or the front wheels raised (less desirable but doable). IF the bearing preload is correct, then you can proceed to the adjustor. The steering has to be centered to make the adjustment. With the steering wheel centered the adjuster is turned in a small amount and then the wheel turned side to side through the center point to feel for a slight resistance at the center point. Adjust, check, adjust, check, etc.
Old 03-11-2017, 04:20 PM   #5
tonydennisadw
screw in clockwise 1/4 turn at a time then check wheel any resistance at all back off till none
tonydennisadw is offline   Reply With Quote
Old 03-11-2017, 04:22 PM   #6
tonydennisadw
sorry this was for the top adj screw only
Old 03-12-2017, 02:14 PM   #7
fordy_nine
The procedure is well-described in the factory service manual. You could do more damage than the $25-30. cost of the manual. You could probably get one from Shoebox Chris........Bob L
fordy_nine is offline   Reply With Quote
Old 03-12-2017, 02:48 PM   #8
terry
When my 48 ford pickup's steering wheel had play in it, I removed a shim from behind the endplate and doing this made a lot of difference. You wouldn't think such a thin shim would make any difference, but it did. Terry
terry is offline   Reply With Quote
Old 03-12-2017, 03:24 PM   #9
JSeery
JSeery's Avatar
Yes, that is why it is important to assure the preload is correct (the adjust with the shims) before you attempt to make any other adjustments.
