I am working on a 49 F1 226 L6 it will not start has fuel spark. I ran a compression test highest cylinder 32 lbs lowest 5 lbs. WTH? What should it be?
Thanks in advance. |
You need to do a leak down test.
Bob |
With those compression figures (especially after oil in the cylinders), your chance of getting it started are mighty slim. I don't know the factory compression on a 6, but it's got to be close to the 110 lbs spec'd for the V8's. They will run OK at anything over 65, but below 50 and you've probably got real problems inside. The only chance you may have is if all of the valves are stuck. If that's the case, you might get lucky if you can get 'em freed up. I've never been that fortunate.
Also, I hate to contradict anyone, but I think it's a little too late for a leakdown test. |
#5 | |
Jimmy |
Bob |
#7 | |
'52 F-1, EAB flathead |
usually if you get no compression in a cylinder that has a stuck valve --you can tell if it is intake or exhaust by listening in the carb/exhaust as you blow air into the cylinder, also if no valve is stuck in that cylinder it will push the piston down. do that in all the cylinders. my advice is to put 50/50 atf and acetone in the cylinders--work real good at loosening carbon gunk on the rings and valves
Thanks all. I brought my compression tester in a older craftsman back when they made good tools. Here are the results. I number cylinders front to back not by firing order.
1st with oil added #1 45lb 60lb #2 55lb 65lb #3 50lb 60lb #4 28lb 45lb #5 22lb 25lb #6 30lb 32lb what I was told about truck. it ran 8 months ago. I so no. The gas in tank was so putrid had to be several years old. How much should I put in each cylinder? What about mystery oil? |
also I used a inspection camera and looked into each cylinder while cranking. everything moves freely no stuck valves.
