Old 12-20-2016, 10:09 AM   #1
Steve T.
Default Local help
I'm wondering if anyone knows of a person or place near Framingham Ma. area who could rewire a 46 ford truck ? I've tried-but it makes me crazy.
Thanks
Steve T. is offline   Reply With Quote
Old 12-20-2016, 11:16 AM   #2
expavr
expavr's Avatar
Default Re: Local help
I recommend investing in a new OEM harness which will come with directions and should be easy to install. The attached thread identifies a couple of manufacturers on the East Coast. I used AnZ in CA and their product with the integrated turn signals was great.
http://www.fordbarn.com/forum/showth...ring+harnesses
expavr is offline   Reply With Quote
Old 12-20-2016, 11:47 AM   #3
woodiewagon46
Steve, there are two "Regional, V-8 Clubs" located in MA. One in Auburn and one in Yarmouthport, I would ask around and give one of them a call. Perhaps one Saturday, invite some club members over and with coffee and donuts you can get your car wired.
woodiewagon46 is offline   Reply With Quote
Old 12-20-2016, 12:17 PM   #4
FRANK PKNY
FRANK PKNY's Avatar
Get a harness from Tyree Harris They are very easy to install.
FRANK PKNY is offline   Reply With Quote
Old 12-20-2016, 12:19 PM   #5
JSeery
JSeery's Avatar
It should be fairly simple to wire (I know it doesn’t seem like it!). The above suggestions are good, or if you have a specific question you can always ask it here. Any of the prefabed harnesses should make the job much easier.
Old 12-20-2016, 12:46 PM   #6
Kerk
The New England Regional group meets the last thursday of the month in the Churcu in Boxborough Congregational Church at &.00 P.M. From 495to route 111 East ""Ä"" 1 mile . Turn Left then left into the church Parking lot. All are welcome. Kerk
Kerk is offline   Reply With Quote
Old 12-20-2016, 04:00 PM   #7
Steve T.
Thanks Kerk, That's not too far from where I am. I will look into it.. I don't see the time, but I'll find it. Thanks again!
Old 12-20-2016, 04:01 PM   #8
Steve T.
Alright, armed with this new info I'm ready to go back to it'
Old 12-20-2016, 04:12 PM   #9
Steve T.
I will search all these tips- Thanks everyone,
Not positive how to reply yet, but I'll get it.
Thanks again..
Old 12-20-2016, 04:20 PM   #10
Steve T.
Thanks for the info !
Old 12-20-2016, 04:23 PM   #11
JSeery
JSeery's Avatar
What are you using for a wiring guide?
Old 12-20-2016, 04:50 PM   #12
VeryTangled
VeryTangled's Avatar
Hi Everyone, I'm not sure, but there may be some related information here... Thanks again Mac VanPelt! http://www.vanpeltsales.com/FH_web/f...electrical.htm
-Jeff H
Old 12-29-2016, 01:55 AM   #13
Steve T.
I have a 1939-48 Ford manual, I have gotten along ok so far but I need to get my act together.
Old 12-29-2016, 06:36 AM   #14
SofaKing
SofaKing's Avatar
I found it easier to refer to the Ford manual and draw my own diagram with each function a separate circuit. This also makes it easier when troubleshooting. My truck does not have all the original switches so an over-the-counter harness would not have been especially useful.
SofaKing is offline   Reply With Quote
Old 12-29-2016, 09:07 AM   #15
funrunr
funrunr's Avatar
As mentioned above and the link VeryTangled listed, Van Pelt diagrams are great.
Buy a correct color coded harness (Tyree Harris is one good suggestion). Once you have the harness, lay it out and label each and every end with a small piece of tape following the diagram from Van Pelt (print them out).
This will familiarize you with the wires too. Now you can begin removing the old wires and installing the new as you go. I was very intimidated when I did my car as this way helped me overcome it. I'm sure others have different suggestions, bottom line is YOU can do it.
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
