Old 11-25-2016, 08:19 PM   #1
farmboy
farmboy's Avatar
Default Any particular antifreeze for a 221 flathead
Time to get my rebuilt truck ready for its first winter since restored. I use the old green antifreeze in most of the farm equipment round the shop. Will that be fine in the flathead. If not what you guys recomend. Thanks.
farmboy is offline   Reply With Quote
Old 11-26-2016, 02:14 AM   #2
40 Deluxe
Default Re: Any particular antifreeze for a 221 flathead
Absolutely will work great. Green is the closest to the original permanent antifreeze back in the day, which gradually replaced alcohol (methanol) based antifreeze. It was called "permanent" because it did not evaporate ('boil') out of the cooling system like methanol, which meant topping off the radiator was a regular chore. Methanol boils at somewhere around 170-180* if I remember. So you changed to 'winter' thermostats (160*) in the fall so the methanol didn't disappear so quickly. Then went back to 180* in the summer. With "permanent" antifreeze you could leave the 180* stats in and get more warmth from the heater.
Old 11-26-2016, 09:32 AM   #3
36Bill
36Bill's Avatar
I use Sierra antifreeze, it is proplyene glycol and is safer for animals.
http://www.peakauto.com/products/ant...motive/sierra/
The best way to have a friend is to be a friend. Howdy Doody
36Bill is offline   Reply With Quote
Old 11-26-2016, 11:42 AM   #4
38bill
38bill's Avatar
Me too, and the insides of my alum heads still look like brand new after 17 years on the road.
38bill is offline   Reply With Quote
Old 11-26-2016, 11:45 AM   #5
flathead4rd
flathead4rd's Avatar
X2 Sierra. Been using it for 20 years in my Flatheads. Just get the antifreeze tester for it as the regular testers won't work. Cost about $2.
flathead4rd is offline   Reply With Quote
