Old 11-24-2016, 06:49 PM   #1
30ccpickup
30ccpickup's Avatar
Default Above the carb
What is it?
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 11-24-2016, 06:53 PM   #2
1930-fordor
1930-fordor's Avatar
Default Re: Above the carb
Vacuum port.
For wippers
1930-fordor is offline   Reply With Quote
Old 11-24-2016, 06:57 PM   #3
taffrail
taffrail's Avatar
Does it go into the valve cover. crankcase vent of some sort?
taffrail is offline   Reply With Quote
Old 11-24-2016, 07:05 PM   #4
30ccpickup
30ccpickup's Avatar
Bigger photo
Old 11-24-2016, 07:07 PM   #5
DaWizard
Send a message via AIM to DaWizard
Holy Smokes !! That looks like something left over from the 70's California smog era.
New owner of '28 Tudor
Previously owned;
'30 Sport Coupe
'28 left brake ccPickup
'31 SW Town Sedan
'28 AA Stake Bed
'30 Cabriolet
'42 Super Deluxe 4door Sedan
"If it don't fit, get a bigger hammer.
If it breaks...... ya needed a new one anyway!!"
Doing a good job here is like wetting your pants in a dark suit.
It gives you a warm feeling, but nobody notices.
Never pass up a bathroom
Never neglect an erection
Never trust a fart
DaWizard is offline   Reply With Quote
Old 11-24-2016, 07:09 PM   #6
ddweave
ddweave's Avatar
Vacuum operated governor maybe?
Doug in Waterloo
ddweave is offline   Reply With Quote
Old 11-24-2016, 07:19 PM   #7
1931 flamingo
1931 flamingo's Avatar
Interesting that the GAV rod seems to line up.
Paul in CT
Old 11-24-2016, 07:31 PM   #8
George Miller
George Miller's Avatar
plus 1
George Miller is offline   Reply With Quote
Old 11-24-2016, 07:34 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
It's a GOVERNOR, so them Thanksgiving Dinner Delivery Kids don't wreck your rusty engine!
Bill Burp!
"THE ASSISTANT GURU OF STUFF"
Old 11-24-2016, 07:39 PM   #10
DaWizard
Hey, how about a close-up the same size as the second pic?
That sure looks like something Jerry Brown cooked up as a smog device.
Also, just an observation, but you might want to take a look at the alignment, judging from that spare, you got some problems
Previously owned;
'30 Sport Coupe
'31 SW Town Sedan
'28 AA Stake Bed
'30 Cabriolet
Never trust a fart
Old 11-24-2016, 07:55 PM   #11
30ccpickup
30ccpickup's Avatar
Note: It is on an unrestored Mail Truck. What would a governor be used for?
Old 11-24-2016, 08:02 PM   #12
Kurt in NJ
Kurt in NJ's Avatar
it limits the engine speed ----back then mail was deliversd in better shape, the truck speed was limited so the packages didn't get damaged
Old 11-24-2016, 08:03 PM   #13
Mitch//pa
To limit the top end speed at a desired setting.
Many commercial vehicles utilized the device
Old 11-24-2016, 08:04 PM   #14
Gary WA
Gary WA's Avatar
Here you go! all the above
www.whidbeymodelaclub.com
Old 11-24-2016, 08:20 PM   #15
30ccpickup
30ccpickup's Avatar
Thanks, and here I was thinking how slow they would be with all the extra body and go figure they slowed them down even more
Old 11-24-2016, 08:48 PM   #16
Bob C
All the mail trucks came with a governor. In the pictures you can see
the bracket to lower the choke rod and a hole lower in the firewall.
Bob
Old 11-25-2016, 02:38 AM   #17
DougVieyra
DougVieyra's Avatar
I think the governor I have works off the Timing Gear, at the rear of the cover. Or do I have something else, altogether different?
DougVieyra is offline   Reply With Quote
Old 11-25-2016, 03:28 AM   #18
Tom Wesenberg
Tom Wesenberg's Avatar
I have one like that also. They were used for saw rigs and air compressors. I'd bet they were also used on the Gleaner combines.
Old 11-25-2016, 11:53 AM   #19
40 Deluxe
This is a "velocity" governor that only limits how fast the engine will rev (so the mailman won't blow the engine as he climbs that muddy hill in low). Engine speed is directly controlled by the foot or hand throttle.
The governor that is gear (or belt) driven is a load-sensitive unit. It maintains a set RPM regardless of load for industrial/agricultural use, where the RPM needs to remain constant, like welders, air compressors, combines, etc. Here engine speed is controlled by the governor; the hand or foot control is connected to the governor, not the carburetor, and the governor controls throttle opening. With no load on the engine the governor closes the throttle plate to maintain say, 2200 RPM. Under a load, the governor opens the throttle plate as needed to maintain the same 2200 RPM.
Old 11-25-2016, 01:01 PM   #20
100IH
40 Deluxe, a good summation of the differences of application.
100IH is offline   Reply With Quote
