Old 07-31-2016, 10:53 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default Rim question
Can anyone advise if there is a 14 or 15" rim that would fit on the rear of a Model A so we can mount two small tires to put on a sedan delivery for transportation in a trailer?? The Sedan Delivery is very high in back from ground to roof, and won't quite fit the trailer.
Thanks!!
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 07-31-2016, 11:29 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Rim question
Some people have even made wood wheels for such a problem, as well as for just moving around the shop.
Old 07-31-2016, 11:34 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Just what my brother did.
Old 07-31-2016, 11:51 PM   #4
Mike V. Florida
Model A wheels are 5 x 5 1/2,
American Motors All 5 lug Jeep, All 2WD (Except 79-85 Eagle, Cherokee, Cherokee Chief) 1942-86
Chrysler 8 cyl. wagon 1946-55
Chrysler Imperial (Special HD) 1954-66
Ford All (Except with Wide 5 pattern) 1928-48
Ford Full size pickup & Vans 1949-96
International Scout, TravelAll
Mercury All 1939-51
Lincoln All 1952-60
Suzuki Samurai 1986-89
are some i found.
Look here as well, http://www.crawlpedia.com/bolt_patterns.htm
Old 08-01-2016, 02:15 AM   #5
CarlG
CarlG's Avatar
My first vehicle was an AA 280A. In order to pull it into Dad's garage, I had to let the air out of the rear tires. The tires were 6.50x20. Didn't have to flatten them completely, but almost.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-01-2016, 04:17 AM   #6
C26Pinelake
We put rims on with no tires and tubes and it worked well. Wayne
C26Pinelake is offline   Reply With Quote
Old 08-01-2016, 06:06 AM   #7
Special Coupe Frank
Special Coupe Frank's Avatar
The 5-lug Jeep wheels will probably be easiest to find, I know they were made in 15"... had a set on my '61 Willy pick-up (made it even slower!).
15" wheels with lmodern low profile tires might achieve what you're looking for.
Special Coupe Frank is offline   Reply With Quote
Old 08-01-2016, 07:41 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Makes me think of Guys that built a BOAT, in a BASEMENT!
A friend bought a HUGE Fridge/Freezer & had to take out a BAY window, to get it inside.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-01-2016, 07:52 AM   #9
SeaSlugs
SeaSlugs's Avatar
youve got to know someone with an older F150 to borrow some rims from.
also bare steel rims still roll
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-01-2016, 08:05 AM   #10
majohnson00
P.m. Sent
majohnson00 is offline   Reply With Quote
Old 08-01-2016, 11:33 AM   #11
Charlie Stephens
Remember that the Model A rims mount at two levels. If you install the later rims and torque them down you will probably deform (and start cracks) the lug holes of the rims leading to eventual failure. I know I wouldn't loan you my late model truck rims.
Charlie Stephens
Old 08-01-2016, 11:55 AM   #12
Bruce
Bruce's Avatar
I agree with SeaSlugs. Get some "sacrifice" 19" rims for the rear. Use them without tires. Put some rubber mats on your trailer ramp and under the spot where you tie down the car inside the trailer. This will effectively lower the back of the truck, but you will have to winch it in.
Bruce is offline   Reply With Quote
Old 08-01-2016, 11:58 AM   #13
SeaSlugs
SeaSlugs's Avatar
yea everyone seems to have a few "yard art" rims around that are rusted thru or so bent they are not saveable but still round and will bolt up.
Old 08-02-2016, 08:32 AM   #14
Bob Bidonde
Bob Bidonde's Avatar
SeaSlugs,
Thanks for posting a photo of your 1929 AA chassis. Good photos of AA chassis are often seen.
Bob Bidonde
Old 08-03-2016, 01:51 PM   #15
captndan
captndan's Avatar
I loaded an older Dodge Power Wagon into a van by letting all the air out of the tires. That worked well but the guy in the truck steering had to make the whole trip inside because there was not room enough to get out a window.
captndan is offline   Reply With Quote
