Old 07-17-2016, 05:41 PM   #1
edhd58
edhd58's Avatar
Default Speedo works backwards
speedo show forward speed only in reverse, and bottoms out in forward gears. i just now got the speedo cable installed for the 1st time since ive owned the car. its a 42 fordor with a 47 rear end. the turtle will only mount in one direction and allow me to install the cable. if i install it reversed to how it is now I have to cut a hole in the frame.
will reversing the way the turtle mounts make the speedo work correctly?
edhd58 is offline   Reply With Quote
Old 07-17-2016, 06:39 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Speedo works backwards
I think you must have the torque tube clocked wrong to force such a mounting of the turtle. Easy check, the center zerk fitting should be straight down at 6 o'clock.
Alan
Old 07-17-2016, 06:54 PM   #3
Kube
Super Moderator
Kube's Avatar
Is the turtle mounted so that the cable attaches to it on the bottom?
Who had the torque tube out? I am wondering if the driven gear - at the end of the driveshaft, was installed backward.
Would that make the speedo run backward? Maybe someone else can answer that with 100% certainty. I think it would but am not entirely certain.
Kube is online now   Reply With Quote
Old 07-17-2016, 06:57 PM   #4
meric42
meric42's Avatar
If the torque tube was installed wrong then the radius rods wouldn't mount to torque tube as they should. The mounting point for the radius rods is also on the bottom???
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 07-17-2016, 06:57 PM   #5
JSeery
JSeery's Avatar
Shouldn't make any difference, the teeth would still be at the same angle.
Old 07-17-2016, 07:05 PM   #6
edhd58
edhd58's Avatar
I swapped rear ends because the original rear end had bad gears and it was cheaper to swap than rebuild. The rear swap was a complete assembly swap, nothing was changed on the "new rear" prior to installation.
Torque tube has the e-brake cable mount welded on, on the bottom of the tube.
Now, for my statement I have to drill a hole in the frame -- well it darn sure looked like i would. After flipping the turtle and reinstalling, the cable passes between the frame and a floor support.
I took the turtle off and checked rotation of the cable drive based on mount and sure enuf, rotation changes if you flip it, so I did, speedo works now.
Old 07-17-2016, 07:07 PM   #7
petehoovie
petehoovie's Avatar
It's refreshing when someone reports back on their 'fix'....
Old 07-17-2016, 07:14 PM   #8
JSeery
JSeery's Avatar
Thanks for the update.
Old 07-17-2016, 07:38 PM   #9
edhd58
edhd58's Avatar
I guess I'm just goofy. This is the first major undertaking I have done and every time I have success with something I feel like a kid and have to share it with someone.
The picture are how it sits today. but still way far from being "done" if it is ever done.
Old 07-17-2016, 07:43 PM   #10
meric42
meric42's Avatar
Good job and nice car - gotta love those rare '42 Fords
Old 07-17-2016, 08:26 PM   #11
edhd58
edhd58's Avatar
i love the delivery sedans.
i like stuff no on else has.
when i finally go down the road I want people to know who it is because of what it is.
I have not seen another 42 around here.
These pics are how it was when I brought it home
Old 07-17-2016, 10:18 PM   #12
RalphM
RalphM's Avatar
Looks like you've done a great job on it!
RalphM is offline   Reply With Quote
Old 07-17-2016, 10:43 PM   #13
meric42
meric42's Avatar
I think that you and I are made from the same stock.
That is exactly why I have my '42's.
I also have a Fordor Ex-army staff car to do one day if I don't run out of time that is
