Old 07-17-2016, 03:05 AM   #1
Rustedjunk
Rustedjunk's Avatar
Default 1947 Ford car cowl harness differences
I was wondering if there is a way to tell the if a harness is a 51A-14401 (47-48), or a 21A-14401 (42-47). Is there any clues or what to look for?
Rustedjunk is offline   Reply With Quote
Old 07-17-2016, 08:35 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 1947 Ford car cowl harness differences
I think it is the location of the ballast resistor, later cars had it on the coil, 46 was inside next to circuit breaker---at least it was that way on the 48 i parted for my 46---as for other differences I don't know---well the 48 just had ignition switch like later car, 46 had steering lock
Old 07-17-2016, 09:10 AM   #3
JSeery
JSeery's Avatar
Looking at the wiring diagrams I see very little difference between these years. The 42 has 6 connections to the lighting switch and the 46-48 has 5 and they are connected slightly different. The gauge power is wired slightly different, the 42 runs a wire to the fuel gauge and then from that terminal a separate wire to the temp gauge. The 46-48 has a "y" in the wire to the separate gauges. Not that much difference that is obvious. All years show the ballast resistor located next to the CBs.
Old 07-17-2016, 04:33 PM   #4
Rustedjunk
Rustedjunk's Avatar
The question arised when I was looking at the Denis Carpenter catalogue I seen two cowl harnesses. One for the 42 - 47 Ford, and the other one for the 47 - 48 Ford. Something about the placement of the voltage regulator. I'm looking to buy one from someone on here and we're trying to make sure it will work for my car before I buy it.
Old 07-17-2016, 04:41 PM   #5
JSeery
JSeery's Avatar
That's not what the wiring diagrams show, so guess owner reports are going to be your best bet. Where is your resistor located?
Old 07-17-2016, 11:49 PM   #6
Rustedjunk
Rustedjunk's Avatar
Mine has the voltage regulator under the dash, which warrants the more expensive harness.
Old 07-18-2016, 01:19 AM   #7
Graeme / New Zealand
Graeme / New Zealand's Avatar
Also last 47s and 48 has different wiring for horns. the relay for it is on firewall and horns behind grill. 42 -46 has horns on left inner fender with the relay mounted on their mounting bracket.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 07-18-2016, 06:21 AM   #8
JSeery
JSeery's Avatar
GB
Again this is not reflected in the wire routing diagrams, very interesting!
Old 07-18-2016, 07:50 AM   #9
Cecil/WV
Cecil/WV's Avatar
Later model has the resister on the coil, not under the dash.
Cecil/WV is offline   Reply With Quote
