I,m assembling a C69a engine,I ordered the main bearings for 1939-1948, the rear bearings won't fit into the block ,they are too narrow on the id of the rear main thrusts,(D dimension) the overall width is right(C dimension) where they fit into the crankshaft,also they only have a narrow locating tag,where as in the block it is a wide style.
looking at my stuff it looks like the bearings I got are for an 8Ba. I think I need the 81a-6331 style. Am I right Lawrie |
Turn the bearing over is there a part # on it?
R |
yes King MB3351S1-020
You are right; 81A prefix.
#5 | |
You need to remove .015"/.016" from the backsides of the thrust surfaces on both shells. We've done a number of these over the years when the early sets weren't available/out-of-stock. Thanks, Gary in N.Y. P.S. Lawrie, on a side note here, this shot may help with another question you asked. These are nice pieces (stainless) considering the cost, just put another large number on the shelf.
http://www.stromberg-bulletin.com/me...berg-equipped/ Last edited by GOSFAST; 07-17-2016 at 06:25 AM. |
What Walt said^^^
R |
I had the same problem and fordbarners came to my rescue. Sealed power sells the 39-48 mains under their number 533M which has a generic number MS 108M while their bearings for a 49-53 are numbered 646M which has a generic number MS 352A. The selling vendor claimed the MS 352a would fit all years. Also barner "barnfind08" had the 39-48 rear main that I needed and would sell me only the rear main.
The Canadian Windsor plant started in with the insert rod bearings a good bit before the 8BA (C8BA) came out. This does make for some interesting combinations since the Canadian C69A has a bit of both eras for bearings.
FWIW the French motors use 59A type main bearings, not 8BA as I first thought. That was an expensive mistake.
Mart. |
