Old 07-16-2016, 07:19 PM   #1
chucksue
Default 1935 wire wheels
How much runout if any is allowed. My rims have .125 wobble.
chucksue is offline   Reply With Quote
Old 07-16-2016, 07:20 PM   #2
RalphM
RalphM's Avatar
Default Re: 1935 wire wheels
The less runout, the better, I've seen worse ones run.
RalphM is offline   Reply With Quote
Old 07-17-2016, 03:52 PM   #3
chucksue
Well I am going to paint them and see how they do. Not many good wheels left. Don't know if I could straighten them.
Old 07-17-2016, 04:28 PM   #4
Andy
I have a set if interested. Where are you?
You do know you need inner support rings if you are using 40-48 drums?
Andy is online now   Reply With Quote
Old 07-17-2016, 06:12 PM   #5
chucksue
I am in central illinois. I have the spacers.
Old 07-17-2016, 07:30 PM   #6
Andy
I have seen spacers too thin. The spacers should be 3/16" thick,
Old 07-17-2016, 08:44 PM   #7
deuce_roadster
deuce_roadster's Avatar
If there is a wheelwright in your area, he probably can true that up. I have watched one work in the Seattle area years ago.
Old 07-18-2016, 07:10 PM   #8
chucksue
My spacers are heavy. Can you send pictures of the wheels and how much do you want for them?
Old 07-18-2016, 07:42 PM   #9
Charlie Stephens
I didn't think they should be that thick. Are you talking about spacers to run disc wheels on mechanical brake drums? To add more confusion, I still don't know if chucksue is running mechanical or hydraulic brakes.
Charlie Stephens
Old 07-18-2016, 08:54 PM   #10
chucksue
I am running 1940 hyd. I bought the spacers from speedway.
Old 07-18-2016, 10:29 PM   #11
Andy
You can measure the required spacer thickness pretty easily. Put a staight piece of metal across two of the supports on the wheel mounting surface. Measure down to the cavity the spacer sits in. Subtract the thickness of your metal piece and that is the gap that needs to be filled.
Check what the Speedway thickness is. Not the total thickness but the raised part.
