Old 07-01-2016, 08:59 PM   #41
40cpe
40cpe's Avatar
Default Re: piston damage (new pictures)
That description sounds like piston slap. The piston warms up and expands.
I think a rod knock would get louder as the oil thins out.
Old 07-01-2016, 09:12 PM   #42
billfish
billfish's Avatar
Thanks for the reply-If it is piston slap, what is the cause and can I live with it if it does not get worse?
billfish is offline   Reply With Quote
Old 07-01-2016, 09:31 PM   #43
Mark's 37
Mark's 37's Avatar
I would run it as it is. If the clearance is tight enough to keep it quiet after getting the engine to operating temp, shouldn't be too bad.
Mark's 37 is offline   Reply With Quote
Old 07-01-2016, 09:37 PM   #44
Bluebell
Did you measure the old and replacement pistons to compare sizes?
It sounds like piston slap, because it goes away when the piston expands in size , as it warms up. A wrist pin is a double click on float just above idle, while the big end is a deeper knock under load.
It's a bit of a shame getting this result after doing all the work.
Bluebell is offline   Reply With Quote
Old 07-02-2016, 12:20 AM   #45
billfish
billfish's Avatar
It is a shame but the idea in the beginning was to do a complete valve job to correct several leaky exhaust valves, That part was a complete success. The replacement piston was checked and was the same size as the old one. It runs and sounds great after a few minutes so I guess I'll keep my fingers crossed and if it changes I know what I have to do. Not fun but not the end of the world.
I assume piston slap is caused by a sloppy fit in the cylinder?
Old 07-02-2016, 04:50 AM   #46
flatford8
flatford8's Avatar
Sorry to hear it wasn't a complete success but I admire your attitude towards the problem. I own 2004 XXX pickup that I paid alot of money for. On a cold winter morning here in Maine, when I start that truck it sounds God awful! Good luck with that great looking car..... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
flatford8 is online now   Reply With Quote
Old 07-02-2016, 07:03 AM   #47
Frank Miller
Frank Miller's Avatar
Because you put a piston in an old engine there may be just a bit more clearance. When an engine is bored it is done to the size of the new piston. Like others said as long as it goes away when armed up it should not be a problem. At least you know there is clearance there.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
