Old 06-22-2016, 11:31 AM   #1
hulleywoodworking
Default All of the @#$%ing Little Leaks!
I am making steady progress on the rebuild of my 51 F1. One thing is driving me crazy-all of the tiny little fluid leaks!
The rebuilt steering box drips about a drop every 3-4 days.
The rebuilt 3 speed sideloader has a very small leak at the back where the countershaft and the reverse gear shaft penetrate the housing-about a heavy drop for each hour of run time.
There is a small leak at the oil pan to block-about a drop a day.
Everything is rebuilt with new gaskets. I used a thin coat of RTV (for gear oil) at the rear end, transmission, and steering box gaskets. I have torqued every bolt to spec.
So-are these little leaks common? What do you all do?
I want to take things back apart and reseal and/or replace the gaskets, but I wonder if that is a fool's errand?
Thoughts and opinions and experiences?
John
hulleywoodworking is offline   Reply With Quote
Old 06-22-2016, 11:37 AM   #2
JT FORD
JT FORD's Avatar
Default Re: All of the @#$%ing Little Leaks!
Good Grief! You're talking about a drop or two a day!!!! I doubt if Henry ever made a car that didn't leak more than that. If he did I never had one. Where talking flat heads.
My F-150 doesn't leak a drop but my shoeboxs both have cardboard under them at both ends.
JT FORD is offline   Reply With Quote
Old 06-22-2016, 11:54 AM   #3
Seth Swoboda
Seth Swoboda's Avatar
All of my early Ford vehicles drip a little oil here and there. Nothing severe just typical drops. I too place cardboard under them to protect the garage floor.
Old 06-22-2016, 12:14 PM   #4
6lucky13
6lucky13's Avatar
You know it's a Ford if you have drip pans or cardboard on the garage floor!
Kerry
6lucky13 is offline   Reply With Quote
Old 06-22-2016, 12:15 PM   #5
RalphM
RalphM's Avatar
Old Fords remind me of when I used to fly in Chinook helicopters in the Army. They leaked hydraulic fluid in the cargo hold, when I asked the crew about it they said don't worry, when it stops leaking then you have a problem.
RalphM is offline   Reply With Quote
Old 06-22-2016, 12:26 PM   #6
amodel25
amodel25's Avatar
An elderly gentleman at a gas station watched me pouring a quart of oil in my avatar (pre-overhaul) and said "It's a Ford.....if it ain't leakin' or smokin' it's empty."
amodel25 is offline   Reply With Quote
Old 06-22-2016, 12:33 PM   #7
Willit Stop
Willit Stop's Avatar
I would just call it a "Rust Prevention System" and get on with my life.
Willit Stop is offline   Reply With Quote
Old 06-22-2016, 12:38 PM   #8
Seth Swoboda
Saves your chassis and floor pans
Old 06-22-2016, 01:29 PM   #9
VeryTangled
VeryTangled's Avatar
John
Hi Everyone, John, in a word, Yes they are common.
I don't expect to be able to drive away from a dry parking spot.
It doesn't help, but in the days these cars were new, nobody had a concrete parking place, all garages had dirt floors.
Also in generations prior to the Flathead, vehicles leaked even worse!
When the new clothes washer showed up I was happy, but even happier to salvage the box!
-Jeff H
Last edited by VeryTangled; 06-22-2016 at 02:20 PM. Reason: Adding photos and comments
Old 06-22-2016, 01:32 PM   #10
Straightpipes
Straightpipes's Avatar
Old Fords mark their spot. Just like the owners leak a little with age.
Straightpipes is offline   Reply With Quote
Old 06-22-2016, 01:57 PM   #11
Joe Immler
If you have an old Ford and it ain't leakin..............you are outta oil.
Joe Immler is offline   Reply With Quote
Old 06-22-2016, 05:36 PM   #12
hulleywoodworking
Thanks fellas for the voices of experience!
I kinda thought that the leaks were normal but wanted to be sure before I decided what to do with them. Which is-leave them be.
Got lots of cardboard, so I'm all set!
Old 06-22-2016, 06:03 PM   #13
oldford2
oldford2's Avatar
Many new Ford (and other brands) dealers in the 50's Gave buyers a drip pan with their name embossed in it to keep your garage floor clean. You can still buy them without the dealer's name at any parts store.
John
oldford2 is offline   Reply With Quote
Old 06-22-2016, 06:35 PM   #14
Steves46
Steves46's Avatar
Now I know why the old driveways were two concrete strips with dead grass in the center.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 06-22-2016, 07:00 PM   #15
Talkwrench
Talkwrench's Avatar
Yup sounds all normal to me.. "If it aint leakin' its got no oil in it!"
Old 06-23-2016, 12:20 AM   #16
outlaw
Talking Re: All of the @#$%ing Little Leaks!
QUOTE=Steves46;1312719]Now I know why the old driveways were two concrete strips with dead grass in the center.[/QUOTE] I never thought about it that way before, but you might just have a good point there! Bill
outlaw is offline   Reply With Quote
Old 06-23-2016, 03:24 AM   #17
51 MERC-CT
51 MERC-CT's Avatar
John
There should not be anything leaking out of the top of the box unless it's over filled.
Believe that the F1 box dimensions are the same as 51' Merc.
Shaft dia. 1-1/4", box C'bore- 1-11/16".
If that's the case then you can remove the pitman arm and install an
(SKF# 12336 oil seal)
Old 06-23-2016, 09:23 AM   #18
hulleywoodworking
It's not leaking at the pitman arm shaft, and it is not overfilled. I'm running 90 wt gear oil, and I think it seeps at various spots-the gasketed covers and the adjusting bolt cap. It's all sealed with the RTV and torqued to spec. After all that I've read I do expect it to seep a little unless I switch over to the Cornhead Grease.
Old 06-23-2016, 09:32 AM   #19
Seth Swoboda
The John Deere "cornhead grease" otherwise called John Deere Multi Lube has provided me with excellent no leak results.
Old 06-23-2016, 09:40 PM   #20
39portlander
39portlander's Avatar
I had that drip out the steering gear, as Seth has stated the cornhead grease replacing the 90W does the job.
39portlander is offline   Reply With Quote
