Old 06-09-2016, 12:33 PM   #1
37 Cab
37 Cab's Avatar
Default Frame number question
A friend just bought a 29 roadster pick up to add to his Collection. There were several cars in this purchase including 4 model As. 3 of them have an engine number that matches the title and State is fine with using those numbers for registration but the roadster pick up has a different engine number than the title. My question is.. Is there only one number stamped on the frame? I have done a search and understand it is located under the cab left front corner. Is that right? Is there another number that is more accessible? Not being to familiar with the model A I also have a couple questions about lifting the cab. How much work is it? Does the running board need to come off to see the number?
Tommy
37 Cab is offline   Reply With Quote
Old 06-09-2016, 12:38 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Frame number question
Yep, just one number on the frame and you'll need to lift the cab to see it. You'll have to also lift the splash apron.
Old 06-09-2016, 12:44 PM   #3
37 Cab
37 Cab's Avatar
Thanks.. Any advise on lifting the cab? Is it just a matter of detaching the steering column, Rad. support rods, choke rod, ect.. then Cab bolts? Are there any hidden bolts I may not see or things I could easily miss? Don`t want to damage anything.
Thank you for your help!
Tommy
Old 06-09-2016, 12:59 PM   #4
mrraford
Lifting the cab is a long day's journey that may not be worth the effort required. Friction has obscured many numbers over the years. You would probably end up having to remove the cab to try to make out the numbers that may still be on the top of the frame.
Engines get changed so it is common for the engine number to not match the vin on the title.
It may be more useful to determine if the number on the title is a valid A number. They were sequential so you should be able to guesstimate the validity based on whether the vin matches the car. Did you say it was a 28-29? there should be a date stamped on the firewall side of the gastank on the drivers side that gives and indication as to when the tank/body was produced.
The car club websites have lists of when the engines were produced so you can infer approximately when the car was produced by comparing the vin with the list. Along with the date on the tank and attributes of the car you should be able to estimate what you have.
Many people put a vin on some other plate in the car and many states accept that as the vin plate.
mrraford is offline   Reply With Quote
Old 06-09-2016, 01:05 PM   #5
37 Cab
37 Cab's Avatar
Thank you.. I will do some homework before lifting the cab. I don`t have the title here but I do remember it starts with an A.
Tommy
Old 06-09-2016, 01:33 PM   #6
Charlie Stephens
Is the previous owner is available and is it possible he would fill out a "Statement of Facts" for the DMV stating that he removed the original engine and replaced it with the one that is currently installed? Better yet is there any chance that the previous owner still has the original engine with the number that matches the title? These might get you through the DMV but every state is different. Worse yet every office within the state is different. And finally every person in every office is different. I hate to confirm the bad news about lifting the cab. You may end up needing to acid etch the number to read it as many of them were faint. Good luck.
Charlie Stephens
Old 06-09-2016, 02:14 PM   #7
russcochiolo
russcochiolo's Avatar
Gents,
I have a Diamond B block cast on April 22 1936 (42236) that has no number stamped on the pad. It does have a Ford number on the flywheel housing with the prefix BB. This was acceptable here in CA and is now the VIN for my roadster. Maybe this will help someone. Russ
russcochiolo is offline   Reply With Quote
Old 06-09-2016, 02:19 PM   #8
Charlie Stephens
Originally Posted by russcochiolo View Post
Gents,
Russ,
Just a bit of trivia. None of the B blocks had a number on the pad on the side of the engine. The number was on a pad at the top of the flywheel housing for the 4 cylinder beginning in 1932.
Charlie Stephens
Old 06-09-2016, 04:58 PM   #9
pooch
pooch's Avatar
It has ben a couple of years since I have lifted and swapped bodies.... BUT.
Do you have to lift the entire cab ?
Remove the floorboards .
Loosen the right side body bolts a bit.
Remove the left side subframe/body bolts.
Remove the left running board .
Remove the front left fender or maybe get away with just removing the hood catches/hood shelf and splash apron bolts. and some front bolts , headlight bar bolts , so the fender can move out at the back about 2 inches.
Probably no need to loosen rear fender to splash apron bolts, but advisable .
Loosen steering column at tank.
Prise or jack up the left side of subframe/ body just enough to slip the splash apron sideways 2 inches.
pooch is offline   Reply With Quote
Old 06-09-2016, 05:17 PM   #10
Benson
I am not telling anyone how they should do it this case ... BUT:
In general when dealing with the DMV in any state or country it is always better to "play Dumb" do not tell them how you had to lift the body on another car.
The person that you are dealing with at the DMV might have been told to just issue a new number or something else which is much easier than lifting the body.
They might say "well if Joe DMV in the next county forced that guy to lift the body then that is exactly what I will do also"! With some it is "a power trip".
You can always wait a while and go to a different DMV office and you might get a better deal if the first person wanted to see you lift the body.
Just saying what I learned over the years.
Old 06-09-2016, 05:25 PM   #11
ronn
PM sent
Old 06-09-2016, 05:32 PM   #12
aermotor
In SC I lifted my body and had a VIN inspector verify the number and issue a statement that this was the true VIN number (which is the same as the engine number). This should follow the car from state to state regardless if the engine number changes or not, true or false I don't know but I have the paper and it was free. The title reflects the same number.
John
aermotor is offline   Reply With Quote
Old 06-09-2016, 08:00 PM   #13
37 Cab
37 Cab's Avatar
I am waiting for a call from the seller. The number on the engine does not have a star prefix or suffix. If the guy can convince me the numbers are correct I am thinking about restamping the block. What do you think?
Tommy
Old 06-10-2016, 08:42 AM   #14
russcochiolo
Charlie (post #8),
Thanks for that info. I will take a look. The BB # that I found was on the side of the flywheel cover. Russ
Old 06-10-2016, 09:39 AM   #15
john charlton
john charlton's Avatar
In England the engine number had to be stamped on the engine itself not the flywheel housing . This was not considered to be part of the engine . If you do have a BB/B motor with a factory stamp on the pad then it is most likely originally from Fords Dagenham England plant . Could also maybe from Cologne Germany but not sure on that .
John in dull warm Suffolk County England
Old 06-10-2016, 03:24 PM   #16
russcochiolo
I just came in from the garage to post these three photos. First one shows the location of the BB#'s on the top of the flywheel cover. 2nd the blank boss. 3rd the casting # D126. In an earlier post I had those wrong.
I can't tell if I got the photo's in......I guess that I just have to submit and see. Russ
Last edited by russcochiolo; 06-10-2016 at 03:56 PM. Reason: didn't get the photos in
Old 06-10-2016, 04:28 PM   #17
Chris Haynes
Chris Haynes's Avatar
Why not get a set of Ford stamps and put your number on your frame in a spot that the fender doesn't cover.
Stamps are available on eBay and parts dealers.
If there are no stars on your engine and the texture where the numbers are don't match the rest of the block you can bet the numbers have been removed and new numbers stamped.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-10-2016, 06:28 PM   #18
Charlie Stephens
My concern would be that if a knowledgeable DMV inspector saw the numbers in a place they didn't belong that it would be bad and go down hill from there.
Charlie Stephens
Old 06-10-2016, 06:43 PM   #19
28RPU
28RPU's Avatar
Charlie Stephens
Just how often does anyone run into a "knowledgeable" DMV inspector? They usually have a hard time finding anything but the coffee pot.
Don’t pick a fight with an old man. If he is too old to fight, he’ll just kill you.
28RPU is offline   Reply With Quote
