Old 05-24-2016, 08:53 PM   #21
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Here's Pictures of the Model A Fuel Filters
I don't know who has the best tank valve because I've only used restored originals.
I always install the added filter to them, even with a clean tank.
Old 05-25-2016, 01:17 PM   #22
Bill in SoCal
Bill in SoCal's Avatar
Originally Posted by Tom Wesenberg View Post
I forgot to mention, look at the fuel flow through the cast iron sediment bulb filter. It's the only filter I know of that filters from the inside to the outside.
If the screen catches debris inside - makes you wonder why they put a drain in the bottom? Bill
Bill in SoCal is offline   Reply With Quote
Old 05-25-2016, 06:03 PM   #23
Tom Wesenberg
The screen must pass water, and the drain cock will dump the water. I know some screens are so fine that they can pass gasoline, but not water. I haven't tried that test on this screen.
