Old 04-17-2016, 01:59 PM   #1
Ianrhall
Default Correct diff oil 8" ford
I had to change the pinion oil seal on my falcon, has a regular non posi diff. About a pint of thick gloopy black oil came out! The regular gear oil I used was much thinner. I'm pretty sure it's noisier now!
Just wanted confirmation on the correct grade of oil
Ian
Ianrhall is offline   Reply With Quote
Old 04-17-2016, 04:13 PM   #2
ponymare
Default Re: Correct diff oil 8" ford
The orig oil was 85-90, but, during its life time a pint or quart of stp may have been added to quiet bearing and gear noise.
ponymare is offline   Reply With Quote
Old 04-17-2016, 05:10 PM   #3
Ianrhall
Should I drain it, refill and use stp again?
Old 04-21-2016, 12:07 PM   #4
ponymare
If its noisy why not find out why and fix it, better than having it go down along the hi way.
Old 04-21-2016, 04:52 PM   #5
Ianrhall
Looks like I've messed up the preload tension, will need to get it set up properly, just hope I haven't caused any expensive damage!
Old 04-22-2016, 07:38 AM   #6
bobss396
bobss396's Avatar
With old cars, I'd be inclined to use something like a 90W-140 gear oil.
bobss396 is offline   Reply With Quote
Old 04-22-2016, 07:46 AM   #7
rich b
rich b's Avatar
Most every 8" rear I've worked on has needed new pinion bearings and a speedi-sleeve on the yoke.
Old 04-22-2016, 09:57 AM   #8
Y-Blockhead
Y-Blockhead's Avatar
The shop that built my 8" recommended 90w-140 from the get-go.
Old 04-22-2016, 03:59 PM   #9
Ianrhall
What would cause noise on deceleration?
Old 04-22-2016, 05:49 PM   #10
Dobie Gillis
Dobie Gillis's Avatar
If you notice that the howling noise only occurs during deceleration, then it is a good indicator that the pinion-bearing preload has loosened. Since you think you may have "messed up" the pinion preload I'd vote for that as the cause.
Dobie Gillis is offline   Reply With Quote
Old 04-23-2016, 03:10 AM   #11
Ianrhall
Just hope nothing else is damaged
