My 6v horn relay was not working and prior owner changed system to 12v. Put in a '56 Ford 12v relay and have changed the 6v horns to work in-series to accommodate the 12v change. Each horn is mounted on a vertical metal strut that comes up thru the belly pan in front of the radiator. Those struts provide each horn with separate electrical ground connections.
Horns were made by Sparton and castings are imprinted "LO" (right side) and "HI" (left side). Main body is die-cast metal and dome covers stamped-steel. The die-cast body did not rust and mild surface rust on and inside the domes cleaned-up nicely. Substituted the metal strut under the left horn with a matching home-made polyester piece (88 cents at Walley), eliminating its elec ground connection. Then connecting that horn to the right hand horn lets them operate in series. Although the voltage thru the circuit is dropped, I notice that the loudness of the right hand horn seems comparatively less .... no big thing .... one can switch the "HI" and "LO" pitched horns if desired. Oddly, the horn trumpet opening faces upward. I thought that was an invitation to water damage but any water that leaked in was able to drain out an opening in the bottom of the assembly leaving limited damage. The manufacturer provided a durable design and brass nuts on all parts. (here come the playful comments) |
Horns cant work connected in series, have to be in parallel. Either run them on 12 volts for a louder and rough out of tune sound or with a resistor in series with each horn to drop the supply voltage to 6 volts for the correct in tune sound. Regards, Kevin.
#3 | |
Charlie Stephens |
Kevin, Drbrown wasn't asking if it would work, he was telling how he made it work.
Kinda looks like the key to invention is to not have advance knowledge that it won't work.
Alan |
I connected two 6volt horns to 12 volts in series by mounting on a wood insulator, had one a little louder so I switched positions and was so loud every neighbor on the block looked out their front door to se where the freight train was coming through, Had one hell of a shock when I touched the wires to the battery. I didn't use a relay I had just purchased them from a swapmeet and was testing them.I only had a 12 volt battery.
When converting to 12V I used a 60 ohm resistor to make my stock 40 Ford BATT gauge operate on 6 volts. This may help.
http://www.fordbarn.com/forum/showth...rting+12+volts |
The horn are a switch operated at a specific frequency so connecting 2 with different frquencys in series will not be working very good.
You get lower output and frequency cause they will "misfire" when one is open and the other doesn´t get any current. Operating them at 12v for a short period will probably not burn them up but you get a higher pitch from them. So a dropping resistor as stated above is the correct way. |
I connected my trumpet style '41 horns in parallel and ran them on 12V for years. Of course I didn't blow them for extended periods of time. Finally burned one out when I hit a large pothole in Ohio and the relay stuck. Thought they were going to blow the paint off the hood before I could get them disconnected!
The horns DO work when connected in series. At least mine do. To add .... my horn circuit is on a 30 amp fuse. A member in the forums tested his 6v horn circuit and found it didn't draw more than 20 amps. If the relay or horns malfunction and draw more current the fuse will blow.
#11 | |
#12 | |
#13 | |
It was not uncommon in-the-old-days for a horn relay to freeze or malfunction, and the driver or mechanic would dash under the hood to pull the wires apart. |
#14 |
You can run the horns in series if one is electrically isolated. They will not be as loud as they could be. This is because they make/break each other's circuit, but it does help to keep the current down a little - start-up current will still be high though.
It is far easier to run them in parallel as original and have them be louder. If you still have a 6V horn relay, they are often better than 12V replacements because the contacts are often heavier. But I've found that aftermarket relays are better still. The horns, which already draw high current, particularly on start-up, will draw double that on 12V. I really like to find and use the 48-52 F1 dual trumpet horns - man are they loud on 12V. But most trumpet horns will be nice and loud. The other thing I like about the earlier horns is most are adjustable and the contacts can be cleaned. Pull the bell off the back and you can dress the points, replace any frayed wires, and adjust the tone/sound/volume.
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch! T5 Tech |
#15 | |
Finding a high wattage, low ohm resistor is likely a challenge, but it might work - would need to know the impedance of the horns to say if that was the correct value or not. It's likely very close though, just by gut feeling...
#16 |
How about a dropping resistor for an ignition coil ?
Is in the right range and should probably survive normal use... |
#17 | |
Flat Ernie: www.digikey.com/products-search .... an on-line company that offers wide range of resistor sizes and types, as well as other electronic items at reasonable prices and shipping for small orders. They sell a "Dale #RW-50 50watt 0.5 ohm which is encased/mountable abt 2 inches long. Last edited by Drbrown; 04-04-2016 at 10:55 AM. |
#18 |
I was more thinking about the modern ceramic square ones usually around 0.5ohm.
The voltage drop is depending on the current going through the resistor so one dropping 3v in one aplication can drop 1v in another. |
#20 | |
