Old 10-24-2015, 06:05 PM   #1
charles in east texas
charles in east texas's Avatar
Default Starter bushing, brush end
Where do you fellows buy your bushings for the end plate with the brushes for a model A ford. I've had no luck with the ones from a vender. Thanks, charles
charles in east texas is offline   Reply With Quote
Old 10-24-2015, 10:16 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Starter bushing, brush end
Mikes a fordable, http://www.mikes-afordable.com/product/A11052.html
Old 10-25-2015, 01:18 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Unless it's actually worn out there is no need to replace it. Total time on a starter is very little and the rear bushing has very little load on it. That said, if I had to replace the bushing (I've only had to do a couple) I either bought it from Bert's, Bratton's, or Snyder's, and it fit fine.
I also have a very good seal and bearing store about 5 miles away where I can buy parts if I need to.
Old 10-25-2015, 12:09 PM   #4
Tom and others, I bought 3 from one of the venders mentioned above and had no luck with them. Maybe need to try a different one. Thanks for the help guys.
Old 10-25-2015, 10:01 PM   #5
Tom Wesenberg
There were two sizes available (see Service Bulletins), but the parts houses only have one.
Old 10-26-2015, 11:42 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
What's the discrepancy?
Old 10-27-2015, 10:03 AM   #7
So that's where the problem lies, Tom.
Charles
