Old 09-21-2015, 03:36 PM   #1
billyboy
Default Cowl Stainless Steel Band Installation
Have 31 ford coupe. Looking for information on where to locate the mounting studs at bottom of band. My body has no holes for these studs. Assistance requested in locating where to drill the holes in body.
billyboy is offline   Reply With Quote
Old 09-21-2015, 08:08 PM   #2
andyfresno
Default Re: Cowl Stainless Steel Band Installation
Billy,
A 31 Ford Coupe cowl has the holes for the band since birth, and a boss to support the nuts on the studs.
Have you got a pic of this area of your cowl? --
andyfresno is offline   Reply With Quote
Old 09-22-2015, 09:59 AM   #3
TomballMottershaw
I had to weld on a longer bolt to get mine to fit, and the nut threaded on.
getting the initial stretch / setting the curve takes more bolt than they gave me.
TomballMottershaw is offline   Reply With Quote
Old 09-22-2015, 10:16 AM   #4
Steve Wastler
Steve Wastler's Avatar
Being from Tomball, you must know Bob Hitchcock from Magnolia! If so give him my best.......
Steve Wastler is offline   Reply With Quote
Old 09-22-2015, 12:37 PM   #5
Big hammer
Cowl band stud should be at a 30 degree angle to the band, near the cowl bottom there should be a slot for the stud, inside cowl there should be a boss at a angle for the stud. Get one side one first then back off nut to the end of the stud, then work on the other side. Studs can be short if body work has been done ( poorly )
Old 09-22-2015, 02:59 PM   #6
andyfresno
all correct
Old 09-22-2015, 03:33 PM   #7
billyboy
Originally Posted by andyfresno View Post
Billy,
Thanks Andy for reply.
No holes visible from exterior. Currently car in paint shop. Will try find the boss later.
Old 09-22-2015, 03:36 PM   #8
billyboy
I have no slot visible from exterior for the band stud to enter. Will try locate boss on inside after car comes back from paint shop.
Thanks for information.
