I have a bunch of old coils and I was planning on sending one to skip to rebuild as a spare for my 38. I have a brown and a black one both ford script but different in appearance.
Which one should I rebuild? |
do both. same postage. What they say. A pair and a spare.
The brown one is the hardest to find......
#4 | |
Super Moderator
If authenticity matters to you, the brown coil is the way to go. By the way, the black coil you have requires a unique condenser which are very difficult to procure. That may be a serious consideration when deciding to invest in its rebuild.
Here is another Two I have with old condensers still attached.
#6 | |
The brown one in post #5 does not have the Ford script, so is probanly after market. I think the brown look nice when combined with the brown end caps on the '37-'41 distributors. Not sure what the judges would say about that on the show field, but I could care less about that. Those black coils are interesting. Have not seen many of those. Not sure why it may use a different capacitor, unless it has a different type of mounting. I would definitely get them rewound using components with modern, high temperature rated insulations. Any of those original coils are subject to shorting windings/turns under heated conditions.
I wonder if the black ones are from tractors?
I have some from tractors that do not look like those.
Which ever coil you rebuild make sure it fits your distributor first.There are three screw coils and later 2 screw coils.
See something new every day, never seen one of the black ones. Walt
Super Moderator
Did you happen to read post #4?
I was not making that up. The black one was made exclusively for the (properly) Detroit Street Railways.
#13 | |
I have seen a couple of those condensors and wondered what they fit........pretty simple mounting.... |
#14 |
Super Moderator
Exactly John...a different mounting. I have a few of these coils with some NOS condensers. I have always wanted to use one as I like "different" on my restorations. However, "correct" and documented as such has always trumped "different". If and until I might find proof these were utilized in "normal" car production, they will remain in the drawer, unused.
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 09-13-2015 at 05:15 PM. |
#15 | |
I find it surprising that 2 I found in Nova Scotia at different times would be that far from home. I've seen a few black ones down this way at swaps and other peoples collections. I actual thought they where more popular than the brown ones. |
#16 | |
Super Moderator
As you no doubt realize that while many Ford parts were built in plants outside the USA, many domestic parts were shipped abroad as well. Very often the parts shipped for international consumption were "different" than the USA counter-part. by "different" I mean in design and / or quality level and / or obsolete (for USA), etc. It does not appear that authenticity is a big concern for you. If I am correct I would suggest you get the brown coil rebuilt as proper condensers are readily available.
#17 |
Another view of the black ford and and brown aftermarket.
#18 |
Brown and black ford. F-6 stamped into the black one.
#19 | |
Here is a close up of the aftermarket stamp. |
#20 |
Super Moderator
I think that is exactly the idea (design) with the black one - more windings. I am only guessing here but in 1942, Ford changed the coil design to look a lot like the black one you have AND they moved it away from the front of the engine. Why? My guess is Ford knew (finally figured out) that the location and design of the coils '37 through '41 was not real good. A larger coil (more windings) and moved away from a "heat sink" proved to be a much better design.
