Old 09-12-2015, 11:45 AM   #1
Bud
Bud's Avatar
Default 16 inch wheels
Do 16 inch wheels really allow a Model A to handle better and give a nicer ride than say 19 inch wheels, disregarding authenticity for the moment?
Bud is offline   Reply With Quote
Old 09-12-2015, 11:49 AM   #2
J Franklin
J Franklin's Avatar
Default Re: 16 inch wheels
A bit on the ride. Steering may be harder.
Old 09-12-2015, 03:40 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
16's is a CLASSIC RETRO MODEL A LOOK. Slightly harder steering helps us to get STRONGER!----Anything worth anything, IS NOT EASY.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-12-2015, 04:53 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
It sure would be hard to beat the LOOK of one of these. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-12-2015, 06:37 PM   #5
rob63mess
rob63mess's Avatar
Love the green coupe.....are the front and rears different sizes?
rob63mess is offline   Reply With Quote
Old 09-12-2015, 06:43 PM   #6
1931 flamingo
1931 flamingo's Avatar
I'd say yes they are diff, big'n'littles.
I think age and condition of tires either 16" or 19" have a large bearing on how a car rides/steers. JMO
Paul in CT
Old 09-12-2015, 07:56 PM   #7
monto
monto's Avatar
My experience (and opinion):- Definitely better on the ride. Steering the same.
monto is offline   Reply With Quote
Old 09-12-2015, 08:20 PM   #8
BILL WILLIAMSON
For easier steering on a Model A, regardless of tire size, be SURE to maintain 35 Lbs tire pressure. Minervas' 19's got down to 12 Lbs, DIDN'T even look low, steered like a MACK TRUCK.
Bill W.
Old 09-12-2015, 08:51 PM   #9
J Franklin
J Franklin's Avatar
Must'a had petrified sidewalls!?
Old 09-12-2015, 08:53 PM   #10
burner31
burner31's Avatar
Won't 19's give you better gas mileage?
And higher speed.
Keith
Shawnee OK
'31 SW 160-B
Old 09-12-2015, 09:19 PM   #11
Floats
Floats's Avatar
Hi Keith,
You are correct BUT 19 inch wheels with 'bicycle' tyres are about the same size as 16 inch wheels with normal car tyres. Hovever fatter tyres must have a bit more friction and drag than thin ones
At the end of the day, I think it is much the same. I think your arugment is good for 21 inch wheels as on my 28 RPU.
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 09-12-2015, 09:26 PM   #12
BILL WILLIAMSON
Quite new Firestone Deluxe, I must have not checked the pressure for a YEAR! (DUMB!)
Bill W.
Old 09-12-2015, 11:08 PM   #13
Randy in ca
Randy in ca's Avatar
My Roadster handles and rides very nicely with 16 inchers!!
Randy in ca is offline   Reply With Quote
Old 09-12-2015, 11:49 PM   #14
Richard/Tennessee
Richard/Tennessee's Avatar
i M RUNNING 16 RADIALS 225 75R 16 GOODYEARS, RIDE,HANDLING AND BRAKES ARE MUCH BETTER, BUT GLENN IN CA THINKS THEY MAKE YOUR CAR LOOK FUNNY, MAYBE SO, BUT I WONT SWITCH BACK
Richard/Tennessee is offline   Reply With Quote
Old 09-13-2015, 10:14 AM   #15
Bob Bidonde
Bob Bidonde's Avatar
I have 18" diameter 1932 Ford wheels with 5.50 tires on my Coupe. The ride smoothness is much better, but the steering effort is much greater. Use a shortened Pitman Arm to reduce the steering effort. The rolling diameter of the 18" wheel is approximately 29".
The rolling diameter of a 19" diameter wheel with 5.00/4.75 tires is also approximately 29". Using 6.50 tires on 16 wheels will also have approximately a 29" rolling diameter.
Bob Bidonde
Old 09-13-2015, 10:49 AM   #16
taffrail
taffrail's Avatar
I love stock Model A's, but that chopped green coupe is the balls!
taffrail is offline   Reply With Quote
Old 09-13-2015, 11:12 AM   #17
40 Deluxe
How about braking with 16" tires? With more rubber on the road, stopping distances should be much shorter. Are they? Can you still lock up the wheels with 16 inchers?
Old 09-13-2015, 06:43 PM   #18
waxhead
waxhead's Avatar
I can lock up all 4 wheels with my 16s and Ted's brake kit. Can't comment from experience on reduced braking distance as my pickup has always had 16s on it.
waxhead is offline   Reply With Quote
