Old 09-02-2015, 07:30 PM   #1
Ccullum
Default 1 1/2 front leaf spring shackle bolts
Good Evening All, need a little help with locating the front leaf spring bolts. Any one have any photos or part number for those bolts, mine are worn bad. Any help is greatly appreciated. 1 1/2 ton 1941 Ford
Ccullum is offline   Reply With Quote
Old 09-02-2015, 08:24 PM   #2
Bob C
Default Re: 1 1/2 front leaf spring shackle bolts
Part number 355521-S 3/8"-24 x 7" Special square head bolt.
Bob
Old 09-02-2015, 08:26 PM   #3
barnfind08
What bolts where?
barnfind08 is offline   Reply With Quote
Old 09-02-2015, 08:51 PM   #4
Ccullum
That is the tie bolt, thank you for that, I am looking for the shackle bolt/bushing/pin, that connects the leaf springs to the shackles. In the front.
There are a total of six of these, three on each spring, square ends with crown nuts on each end.
Old 09-02-2015, 09:10 PM   #5
alan
measure the width and dia. I may have a few, also requires a very thick washer. on 42 up these were changed to a slightly different set up. try chuck's truck in conn, I believe,
alan is offline   Reply With Quote
Old 09-02-2015, 09:44 PM   #6
Ccullum
You got it, has a super thick washer on one end where it connects to the frame.
The length is 4 1/2" tip to tip, with approx 5/8" square ends and approx 1/2" maybe 7/16" dia thread tips where the crown nuts go on.
