Old 08-30-2015, 07:01 PM   #1
russcc
Default Aging aulminum heads
Have a new set of aluminum aftermarket heads. They will look way out of place on old Betsey. Is there a way to age them besides fine bead blast. I don't have immediate access to a bead blaster. How about phosphate used to prep metal or soda blasting ? Other experiences ? Thank you Fordbarners.
Old 08-31-2015, 12:42 PM   #2
russcc
Default Re: Aging aulminum heads
Any ideas on knocking the newness of these Navarro heads. Please see photo. Got them from Barney at Navarro Engineering in Glendale before he left us.
Old 08-31-2015, 12:54 PM   #3
Tinker
Tinker's Avatar
Dirty Grease and oil?
Old 08-31-2015, 01:11 PM   #4
corvette8n
corvette8n's Avatar
Just put them on and run them, personally I would be hesitant about using chemicals.
Old 08-31-2015, 01:24 PM   #5
Jim Huseby
Jim Huseby's Avatar
Here's an idea that will get you an appearance similar to what you want and still let you return them to new appearance easily. Wash, rinse and dry them with PPG Alumaprep as per instructions on the bottle. Then spray them VERY lightly and somewhat unevenly with red-brown oxide Krylon and an even lighter mist of flat black, if needed, to desired effect. Go light, so that the aluminum gets just barely tinted. The Alumiprep treatment will keep the primer from wanting to scratch and flake. If you don't get the effect you want the first time, the primer and paint will wash off with lacquer thinner and you can modify your technique. Then as the years tick by, nature will pick up where you left off and will give you the real thing.
Jim Huseby is offline   Reply With Quote
Old 08-31-2015, 02:32 PM   #6
Pete
I would hang them on the wall and buy an old used set to run.
Old 08-31-2015, 03:56 PM   #7
Ralph Moore
Ralph Moore's Avatar
I was going to say sell them and buy an old set!
Ralph Moore is offline   Reply With Quote
Old 08-31-2015, 04:02 PM   #8
scooder
Put um on and run em hard, they'll soon get some age, of that's what you want.
Give Barney the respect he deserves, and run them. He didn't make um to hang on the wall.
Arnt we repeatedly being told that old used high compression heads are more trouble than there worth? And buying new is best?
Martin.
scooder is offline   Reply With Quote
Old 08-31-2015, 05:23 PM   #9
dude
dude's Avatar
Martin.
2X I agree..
[QUO[/QUOTE]no matter where you are,or where you're at, there you are...
dude is offline   Reply With Quote
Old 08-31-2015, 05:25 PM   #10
markivpedalpusher
markivpedalpusher's Avatar
Easy off oven cleaner gives aluminum an aged look. Spray on let it sit for 5-10m, rinse and repeat until desired appearance.
markivpedalpusher is offline   Reply With Quote
Old 08-31-2015, 06:14 PM   #11
russcc
Thank you all for your suggestions. Right on, Barney would expect I would run them, not hang them on the wall. If I could have found an original set of Navarro's, I would have bought them. No luck, but I got a chance to meet Barney in person, and tour Navarro Engineering. The 700 HP turbocharged Indy motor was cool. Barney was always light years ahead of the times. The Easy Off is a great idea, and simple. Thanks again.
Old 09-01-2015, 12:30 AM   #12
40 Deluxe
Send them to me and I will return them, properly aged, in about 15 years!
Old 09-01-2015, 08:19 AM   #13
jimalabam
jimalabam's Avatar
Great answer 40 Deluxe...
jimalabam is offline   Reply With Quote
Old 09-01-2015, 04:51 PM   #14
Ronnieroadster
Ronnieroadster's Avatar
Spray them with liguid sodium silcate also known as water glass the surface texture and shade will change becoming darker and duller.
Old 09-01-2015, 05:14 PM   #15
48 coupe
48 coupe's Avatar
the oven cleaner will work Have the heads warm and don't rinse them let um dry.then put some oil on them run it. dirt and all for a while. Just be sure you want them to look old.
48 coupe is offline   Reply With Quote
Old 04-17-2017, 08:22 PM   #16
PeteVS
PeteVS's Avatar
I have an older aluminum manifold that I had bead blasted to clean it up. Came out nice but it was sort of pure aluminum looking which is just about white. So, I borrowed the wife's Easy Off spray, sprayed it and let it sit for a short while. Then I rinsed it off. It had darkened up nicely but I wanted it just a bit more. Sprayed it again and let it sit for 5 or so minutes, rinsed it off and it's just what I wanted.
Thanks!!
Old 04-17-2017, 09:48 PM   #17
cmbrucew
cmbrucew's Avatar
You can get oven cleaner at the Dollar stores.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 04-17-2017, 11:31 PM   #18
Lanny
Lanny's Avatar
I used Easy Off on some aluminum pistons years ago, to clean them up,
and I kept spraying coats on ( 4 or 5 ) and let them soak too long.
The pistons got clean, but had little pock marks all over 'em, and in the
ring grooves, so be careful.
Leave some spark plugs in so you don't get any cleaner on the threads,
and don't let any Easy Off get on the deck surface, and flush with plenty
of water when after you get the look you want.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 04-17-2017, 11:58 PM   #19
J Franklin
J Franklin's Avatar
Just paint the engine and make it all shine!
J Franklin is online now   Reply With Quote
Old 04-18-2017, 08:42 AM   #20
A bones
A bones's Avatar
There ya go!
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
