Old 08-14-2015, 12:46 PM   #1
motordr
Default COLUMBIA with 3.78 gears
I would like to hear from anyone that is running a Columbia with 3.78 gears. How do you like it? I am thinking of this for a 32 3 window with a healthy 265 flathead, but with stock wheels and tire size. I have a 4.11 Columbia in my other car and am thinking of going up a step in the gear ratio for this one. Looking for your actual experience on this setup. Thanks!
motordr is offline   Reply With Quote
Old 08-14-2015, 12:49 PM   #2
Pete
Default Re: COLUMBIA with 3.78 gears
I have done that with a 296 in a 32 coupe.
I didn't like it.
Old 08-14-2015, 01:06 PM   #3
Dave/Green Bay
Pete:
What didn't you like about it?
Thanks Dave/Green Bay
Dave/Green Bay is offline   Reply With Quote
Old 08-14-2015, 02:24 PM   #4
PeterC
PeterC's Avatar
Just a comment to consider in your thinking .. Flywheel should be a factor as well - I have a strong 284cu (supercharged) with 4:11 and Columbia with an aluminum flywheel. I my case the 4:11 is great for around town performance and easy launch with the benefit of the 2:97:1 high for lower (28.5% reduction) in RPM at 65mph. I am happy with this combo with the lighter flywheel.
PeterC is offline   Reply With Quote
Old 08-14-2015, 02:44 PM   #5
JSeery
JSeery's Avatar
I would think that the 4:11 gearing would be the better selection. As everyone (so far) is saying good option for both in town and highway. Unless you drive almost exclusively on the highway at high speeds on fairly flat ground not sure why you would want a higher rear end gear when you have an OD.
Old 08-14-2015, 03:14 PM   #6
Pete
Originally Posted by Dave/Green Bay View Post
Pete:
It was geared too tall for passing in direct high.
Old 08-14-2015, 03:21 PM   #7
Kube
Super Moderator
Kube's Avatar
I have installed more Columbia's than I care to recall. The best overall performance in my opinion was attained when coupled to the 3:78.
Old 08-14-2015, 03:56 PM   #8
jimTN
Its gonna depend on where you live, flatland or mtns, urban driving or country.
Old 08-14-2015, 04:32 PM   #9
hotcoupe
hotcoupe's Avatar
i have a Columbia in my `37 1/2 ton with a 22 lb. flywheel on a 239 c.i. motor, single 94 with a Max-1 and a 28 tooth cluster and a 3:78 r&p with 7.00 x 16". and after 4,000 miles, i wouldn`t change a thing. and i know my next statement is going to get a response . . . # 41 jets in the carb. blast away!
tom
hotcoupe is offline   Reply With Quote
Old 08-14-2015, 05:19 PM   #10
Kube
Super Moderator
Kube's Avatar
Good point... around here, lots of hills. None too steep but many are very long.
Old 08-14-2015, 06:27 PM   #11
Don
Don's Avatar
3.78 in my 35 roadster Works greatin hills and on highway
DON P
Don is offline   Reply With Quote
Old 08-14-2015, 07:17 PM   #12
supereal
supereal's Avatar
My '47 convertible has a 3:78 rear, and an overdrive with a 33 percent reduction. it is fine above 45 mph, but lugs below that. It will run at hiway speeds of 60 to 70 mph, which pushes the stock handling and braking to limit. What you select must be based on the intended use, lots of hiway, or mostly city, because the balnce is tricky to reach.
supereal is offline   Reply With Quote
Old 08-14-2015, 07:54 PM   #13
Kahuna
Kahuna's Avatar
I didn't know what a Columbia O/D reduction was? It has quite a drop in RPM.
Kahuna is offline   Reply With Quote
Old 08-14-2015, 08:30 PM   #14
Highboy34
27% reduction as I remember.
Highboy34 is offline   Reply With Quote
Old 08-14-2015, 08:35 PM   #15
PeterC
PeterC's Avatar
per Columbia literature - 28.5% reduction
Old 08-14-2015, 08:39 PM   #16
Bob G/Spanaway
Bob G/Spanaway's Avatar
I have had 3.78/Columbia in both my coupe and PU for around 10 years.
Just '040 over 239 with dual 97's, heads and mild cams.
They work great in all kinds of driving.
Wouldn't change a thing...except maybe the 25 tooth Zephyrs in my coupe.
Bob G/Spanaway is offline   Reply With Quote
Old 08-14-2015, 10:49 PM   #17
Kahuna
Kahuna's Avatar
PeterC
What is your rear tire size? Diameter?
On my 32, I have a Gear Vendors O/D that reduces the final ratio from 4.11 to 3.21.
My tires are 29 to 29 1/2" tall.
In O/D at 65 mph, my engine turns about 2300 rpm. Wondered what yours is?
Thanks,
Jim
Old 08-15-2015, 07:34 AM   #18
48 coupe
48 coupe's Avatar
My 48 has 3.78 columbia max 1 cam 259 ci. offey heads. 2 ecg carbs. 51 jets. light flywheel. pulls good. I think it's a good set up.
48 coupe is offline   Reply With Quote
Old 08-15-2015, 07:37 AM   #19
PeterC
PeterC's Avatar
PeterC
Thanks,
Jim
Rear tire diameter looks like 30" to me - Tire is Coker Firestone bias 700 X16 - I do not have a tach but guess is 2300 rpm sound reasonable.
Old 08-15-2015, 08:57 AM   #20
38 coupe
38 coupe's Avatar
There have been so many discussions about rear axle gear ratios and overdrive that I put together a spreadsheet showing the most discussed combinations. I set the color bands based on my driving experiences with a 3.78 axle, no overdrive car. Obviously other people will have different opinions about comfortable rpm ranges. These calculations are accurate for 1:1 ratio in the transmission and a 28 inch tall rear tire.
I hope this image is readable.
Last edited by 38 coupe; 08-15-2015 at 09:08 AM. Reason: Attempting to get the table clear enough to read...
