Old 08-09-2015, 11:27 PM   #1
Steve Plucker
Default Tail light bulbs for 1928 Drum Tail light...
In looking at the Drum Taillight light bulb attchments, it appears that the upper attachment is for a single contact bulb and the lower attachment is for a double contact bulb both utilizing stright pins for attachment, I think.
That being the case, just what are the bulb numbers associated with each one?
Thanks.
Pluck
Old 08-10-2015, 09:22 AM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Tail light bulbs for 1928 Drum Tail light...
No, they are both single contact bulbs. The lower one is the tail light and the upper one is the brake light.
I assume you want 6 volt bulbs.
The tail light is a #63 (3 cp) bulb.
For the brake light you can use an EIKO A-4513 for the original 21 cp brightness, or an #1133 bulb (32 cp) to be brighter, have the brake light seen better.
Hope this helps.
Jim Cannon
"Have a Model A day!"
Old 08-10-2015, 02:11 PM   #3
Steve Plucker
Hope this helps.
Jim,
Thank you for your reply.
Pluck
Old 08-10-2015, 02:16 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I posted some detailed pictures of the drum sockets in the past. I wonder if a search would still turn them up. I had to repair a couple drum taillight assemblies.
Old 08-10-2015, 05:26 PM   #5
JoeWay
JoeWay's Avatar
Tom, was it Post #5 in this thread?
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 08-10-2015, 08:49 PM   #6
Tom Wesenberg
Yes, thanks Joe.
