Old 05-31-2015, 04:06 PM   #1
jonf
Default Gravity bends a crank?
I had my crank reground 4 or 5 years ago and put it in a box to store it. the box is resting on the floor and the crank inside is parallel to the floor. Is there any truth that all crankshafts should be store vertically?
jonf is offline   Reply With Quote
Old 05-31-2015, 04:09 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Gravity bends a crank?
Yes. I would definitly check it carefully before you decide to use it. In the meantime, stand it up!
Old 05-31-2015, 04:11 PM   #3
zedbyers
zedbyers's Avatar
agreed, there is truth to this, if it is not properly supported while being stored horizontally.
zedbyers is offline   Reply With Quote
Old 05-31-2015, 04:22 PM   #4
JSeery
JSeery's Avatar
This is one of the topics that there is little agreement on, but most believe that the sagging crank theory is a myth. Easy enough to check, run a gauge on it and see what you have.
Old 05-31-2015, 04:32 PM   #5
uncle max
uncle max's Avatar
I'm concerned now... Will climate change bend my crank?
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 05-31-2015, 05:09 PM   #6
rheltzel
rheltzel's Avatar
No, but if global warming causes the seas to rise enough to flood Salt Lake City, it will rust.
rheltzel is offline   Reply With Quote
Old 05-31-2015, 05:18 PM   #7
jonf
Talking Re: Gravity bends a crank?
Well OK then. I will rotate the box 180* and wait another couple of years. If it is sagging this should fix it.
Old 05-31-2015, 05:19 PM   #8
19Fordy
19Fordy's Avatar
Uncle max, The coefficient of thermal expansion of steel is such that unless the extreme temperature is sustained, thereby not permitting the crank to return to its nominal size, the distortion will remain. At least that's my view.
Think of a rail road track expanding during summer and contracting during winter.
I just realized you are joking?
Old 05-31-2015, 05:22 PM   #9
zedbyers
zedbyers's Avatar
on larger (non-automotive) engines, you have jacking gear to turn them over slowly after they have been sitting for a while to remove any distortion from gravity, and this is a crank that is supported. no doubt in my mind that same doesn't happen to an unsupported one. the question becomes what is tolerable. may never even notice it? i can't answer that. but i have to believe that there is measurable change there. if it were a 9000 rpm racing engine, there is probably something to be worried about. these engines, maybe not.
Old 05-31-2015, 05:28 PM   #10
BILL WZOREK
BILL WZOREK's Avatar
It all depends how many Leap years were in the laying down cycle
BILL WZOREK is offline   Reply With Quote
Old 05-31-2015, 05:37 PM   #11
Old Henry
Old Henry's Avatar
I would think that if gravity bends a crank laying on its side too long that standing it on end too long will cause its diameter to spread. . . kinda like my diameter has spread from standing on my end too many years.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 05-31-2015, 05:55 PM   #12
ford38v8
ford38v8's Avatar
Originally Posted by old henry View Post
i would think that if gravity bends a crank laying on its side too long that standing it on end too long will cause its diameter to spread. . . Kinda like my diameter has spread from sitting on my end too many years.
fify
Alan
Old 05-31-2015, 06:03 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
I had to look that one up, Alan. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-31-2015, 06:06 PM   #14
ford38v8
ford38v8's Avatar
http://www.urbandictionary.com
Alan
Old 05-31-2015, 06:08 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
I got 'er figured-out......had just never seen that one before. What the heck do I know? DD
T5 W/TORQUE TUBE
Old 05-31-2015, 06:09 PM   #16
tubman
tubman's Avatar
I have always been amazed at discussions like this. Here's a crankshaft that can take the firing impulses running in an engine for 90-100K miles, and some prople wwill think it will bend sitting on a floor? Give me a break!
Old 05-31-2015, 06:14 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
Soooo, are ya saying cranks don't twist with each firing impulse? There's a difference between "bend", "twist" and "yield point". You ever think about what a harmonic balancer does in conjunction with a crank? DD
T5 W/TORQUE TUBE
Old 05-31-2015, 06:17 PM   #18
FrankWest
FrankWest's Avatar
Gravity is considerably weaker than the forces that hold matter together. The nuclear force being the greatest. You would think the bonds of the molecules in the metal would be many orders of magnitude greater than the pull of gravity on a small tab.
Perhaps it the tab was over a foot then with time it could sag under its weight, and long distance to its connection to the shaft!
FrankWest is offline   Reply With Quote
Old 05-31-2015, 06:30 PM   #19
rowens55
rowens55's Avatar
Unhappy Re: Gravity bends a crank?
Man, you fellers is SMART !!!! By th way, what's a "molyquals"?
Alive n kickin n mostly kickin!
rowens55 is offline   Reply With Quote
Old 05-31-2015, 06:41 PM   #20
rheltzel
rheltzel's Avatar
Molly Cules...she worked at the cafeteria next to the crankshaft foundry at the Rouge plant. Was said to have inspired the workers to make sure their crankshafts were always straight, even if they were laid flat.
