Old 05-20-2015, 09:15 PM   #1
1crosscut
1crosscut's Avatar
Default Is this a correct adjustable wrench for a Model A?
Is the bottom wrench correct for an A?
The person selling it wants $20.00 for all three wrenches.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 05-20-2015, 09:17 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Is this a correct adjustable wrench for a Model A?
Does it say FORD on it?
Old 05-20-2015, 09:22 PM   #3
1crosscut
1crosscut's Avatar
Forgot to post picture
Old 05-20-2015, 09:38 PM   #4
mrtexas
mrtexas's Avatar
Yes, the nub on the end is what makes it Model A.
mrtexas is offline   Reply With Quote
Old 05-20-2015, 10:06 PM   #5
J Franklin
J Franklin's Avatar
Offer him $10. for the A adjustable one. By the others only if you need them. The square bottom is for the differential plugs.
Old 05-20-2015, 11:47 PM   #6
mot
Registered User
mot's Avatar
If your car was made after Nov of 1931 ,the bottom one would be correct
Ford USA
,other wise no
look for just Ford ,or no name
tom
mot is offline   Reply With Quote
Old 05-21-2015, 12:49 AM   #7
redmodelt
redmodelt's Avatar
I think the bottom one is 1926-27 Model T.
Old 05-21-2015, 01:10 AM   #8
Tudortomnz
Tudortomnz's Avatar
The bottom one is Ford V8 to about '41.
As noted by Mot, the Ford USA stamp came in late '31.
Most Model A monkey wrenches only had a manufacturers mark except for 1928 when they did have a Ford script plus manufacturers mark.
The tang for the diff. bung was not unique to Model A's ; the last Model T monkey wrench [ '26 '27] used it for either the regular diff or if it had a Ruckstell.
Tudortomnz is offline   Reply With Quote
Old 05-21-2015, 02:53 AM   #9
billwill
In the day the bottom and top ones Where called MOMKEY WEENCHES
billwill is offline   Reply With Quote
Old 05-21-2015, 07:06 AM   #10
C26Pinelake
My Dad used to say, " Don't be a monkey, get the wrench that fits " ! Wayne
C26Pinelake is offline   Reply With Quote
Old 05-21-2015, 11:17 AM   #11
Rusty Homestead Fl
Rusty Homestead Fl's Avatar
ADJUSTABLE WRENCH:
"All adjustable wrenches were 9-3/8" long and had a square end on the handle, which is used to remove the drain plug for the differential housing. Some wrenches did not have the Ford script". My Judging Standards book is the older version. Has this info been changed?
Rusty Homestead Fl is offline   Reply With Quote
Old 05-21-2015, 11:30 AM   #12
aermotor
You must have to work like lightening to put one end of the wrench in the hole and turn it with the other end or were there two wrenches?
aermotor is offline   Reply With Quote
Old 05-21-2015, 12:29 PM   #13
J Franklin
J Franklin's Avatar
Aermoter, the tool kit came with more wrenches.
Old 05-21-2015, 12:45 PM   #14
CarlG
CarlG's Avatar
The guys were smaller in stature back then, but they had a grip like no other!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-21-2015, 04:57 PM   #15
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Carl,
If I wuz as STRONG as Mitch, I'd be DANGEROUS! I'd go around, ACCIDENTALLY breakin' things! Right now, I have enough trubble jist opening cans with my worn out CAN OPENER
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-21-2015, 09:40 PM   #16
1crosscut
1crosscut's Avatar
Thanks for all of the information gentlemen. I think I'll give him a call and see if we can strike a deal. Not trying to build a correct set of tools for my truck but since it is correct for an A I think that it will look good on my shop peg board along with all my other "wall art".
Old 05-21-2015, 10:11 PM   #17
Bruce Adams
Bruce Adams's Avatar
Ten dollars is an easy find at Hershey for the adjustable wrench with the nub on the bottom for the differential plug. I have purchased them for half that at Hershey from "non'professional vendors".
As Rusty stated and Don Turley supported, page 17-1 of the current RESTORATION GUIDELINES carries Rusty's quotation for the Model A's adjustable wrench.
Bruce Adams is offline   Reply With Quote
Old 05-22-2015, 10:49 AM   #18
mot
Registered User
mot's Avatar
the quote from the JS is correct
but there is NO mention of the USA
the new JS will have the USA after november of 1931 only
so ANY wrench with the USA on them is incorrect until after november 1931
USA is the key word ,not ford script
tom
Old 05-22-2015, 10:58 AM   #19
redmodelt
redmodelt's Avatar
I still say it's Ford Model T.
Old 05-22-2015, 11:25 AM   #20
Mark W.
Mark W.'s Avatar
It will work, but the T wrench is the same as the early A one - Ford script only. They are a bit harder to find - then there is one with no script or markings other than an "M" for the manufacturer of the wrench but exactly the same in every other respect, these are easier to buy with the lack of a Ford script.
No matter - they all sell in the $10.00 range - not much more and sometimes less
Mark W. is offline   Reply With Quote
