Old 05-17-2015, 07:35 PM   #1
1962300
Default Head Stug Leakage
Freshly rebuilt late 40's, crab cap flathead.
New head studs, washers and nuts that hold down Edmunds Aluminum Finned Heads.
I have broken in the engine and re-torqued the heads.
There seems to be a bit of coolant escaping from one head bolt on each side.
What is the recommended trick to close up the leak?
Maybe roll a rubber o-ring or two down the stud?
Thanks
1962300 is offline   Reply With Quote
Old 05-17-2015, 07:50 PM   #2
JSeery
JSeery's Avatar
Default Re: Head Stug Leakage
Some of the head studs require sealant as they go into the water jacket. Were they sealed properly when they were installed? Don't think you want to be messing with o-rings and don't think that would work anyway.
Old 05-17-2015, 07:59 PM   #3
48 coupe
48 coupe's Avatar
Just drive it for a while .It will most likely stop . mine did.
48 coupe is offline   Reply With Quote
Old 05-18-2015, 12:49 AM   #4
GEOFFNZ
I agree .Have had the odd one leak but seem to seal after some use.Of course they should have been better sealed initially.Geoff
GEOFFNZ is offline   Reply With Quote
Old 05-18-2015, 08:01 AM   #5
stangblue
stangblue's Avatar
Ha! Had same problem put teflon tape on the stud into the block and Permatex under the washer and threads where the head nut is. Of course had to call wife into garage to put finger on hole of head to keep water and anti-freeze from pouring all over the place. Seemed to rectify leak so far.
Assumption is the mother of all foul-ups.
stangblue is offline   Reply With Quote
Old 05-18-2015, 08:13 AM   #6
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
As they say they usually seal up but some are stinkers, I remove the nut smear RTV on the stud and torque the nut back on. Walt
Old 05-18-2015, 11:01 AM   #7
Ronnie
Ronnie's Avatar
http://barsleaks.com/product/radiato...-leak-tablets/
Or remove the studs one at a time and seal with permatex
http://www.permatex.com/products-2/p...-liquid-detail
R
Ronnie is offline   Reply With Quote
Old 05-18-2015, 02:30 PM   #8
my4dv8
Forget the o ring idea , very much doubt it will help at all. Best idea is to pull the suspect stud out ,thoroughly dry out the offending holes slather the very clean stud and hole with loctite #3 non hardening sealer .and as an extra help you could grind up a seal well block and add it to boiling water to dissolve it and then add it to a warm radiator to allow it to circulate.
my4dv8 is offline   Reply With Quote
