Old 04-16-2015, 09:54 AM   #41
the cooch
the cooch's Avatar
Default Re: two carb setup
Too cold up there Ralph! A little heat helps the fuel lines bend. I put the little guys in the oven for a few last time. Torch is overkill and would make thin spots, i think, but I get easier, better looking bends by hand with the lines hot than with any tool I've tried. I do like the spring style for big curves, but always get a kink from the plier style with the wheel on small corners. Could be a placebo effect, haha, but theres a nice feel to it.
the cooch is offline   Reply With Quote
Old 04-16-2015, 11:09 AM   #42
blucar
blucar's Avatar
A very clever body man showed me a neat trick to loosen frozen/stuck nuts, bend tubing, etc.,
Use an electric heat gun. The heat can be controlled without distorting the metal. Works great on pot metal/cast trim pieces that have been bent. Heating the piece with a heat gun will allow the piece to be straightened without it breaking.
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 04-16-2015, 11:31 AM   #43
funrunr
funrunr's Avatar
Originally Posted by Ralph Moore View Post
I've been trying to make a fuel line doing the same, but I'm having a heck of a time bending them. Seems every time I get to a 90, it kinks on me.
I have a nice bender, and it worked great on my brake lines, but the larger 5/16" lines are just not working. Any secrets?
I have a couple benders, however I used the cheap one. Notice the lines I used are the softer metal ones that they sell in shorter lengths. It has some coating to prevent rust and bends easier. I cannot remember the name as this was a few years ago. However I took a close-up for you. When you go into Napa you will recognize by the different color. If you cannot find it I will stop in our location here and get the name for you.
Good luck, Mark
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
Old 04-16-2015, 11:55 AM   #44
V8COOPMAN
V8COOPMAN's Avatar
It's Kunifer Brake Pipe. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-16-2015, 12:28 PM   #45
Ross F-1
Ross F-1's Avatar
Cunifer
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 04-16-2015, 01:19 PM   #46
Mike51Merc
Mike51Merc's Avatar
It's not a good idea to remove your choke plate, even if you don't use the choke. Air flow studies have shown that these carbs flow less with the choke plates removed.
As far as running two carbs with progressive linkage, it depends on your manifold. Most manifolds have equalization tubes between the two plenums, meaning that both carbs feed all eight cylinders, not each feeding four cylinders. I've set up engines with both direct and progressive linkages successfully.
Mike51Merc is offline   Reply With Quote
Old 04-16-2015, 01:23 PM   #47
Mike51Merc
Mike51Merc's Avatar
Originally Posted by tubman View Post
I have never run a regular dual manifold (just "super-duals" and 4BBL's), but it seems obvious to me that using the rear carb as the primary would seriously starve the front cylinders. I may be wrong, but if I am, I'd like someone to explain why.
As I posted above, most multicarb manifolds have equalization tubes inside that join everything together.
As far as starvation from distance away-- just look at any six cylinder manifold and how far the carb is from the end cylinders compared to the middle cylinders. Do they starve?
Old 04-16-2015, 01:31 PM   #48
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Ross F-1 View Post
Cunifer
You're absolutely correct Ross, and I did know there was a difference. I've even written about it in the past. I grabbed the wrong straw this morning without properly checking myself. DD
T5 W/TORQUE TUBE
Old 04-16-2015, 07:42 PM   #49
tubman
tubman's Avatar
All well and good, but how many six cylinder intakes have you seen with the carburetor on the end? Everything is a compromise, but we are better of with the best configuration we can find.
Old 04-17-2015, 08:47 AM   #50
Mike51Merc
Mike51Merc's Avatar
No, the carb's in the middle and it has to feed cylinders at the ends!
Old 04-17-2015, 11:27 AM   #51
Ralph Moore
Ralph Moore's Avatar
Thanks Cooch, your probably right about the cold, I turned the heat off in my shop a couple weeks ago( no longer freezing), but it's about 45 degrees in there now, unless I build a fire.
Ralph Moore is offline   Reply With Quote
Old 04-17-2015, 11:29 AM   #52
4ford
just did the sync and seems to run ok. the linkage sucks its from speedway and has cotter keys I the ends and feels tight. any one have a different source of a better one its a solid linkage....
4ford is offline   Reply With Quote
Old 04-17-2015, 12:17 PM   #53
flatjack9
flatjack9's Avatar
The linkage isn't the greatest. I've had to open up the slots to make them work or they bind on the carb levers.
Old 04-17-2015, 12:53 PM   #54
PeterC
PeterC's Avatar
My setup is solid linkage with single active choke and one locked choke plate front - carbs are 48's. starts great when cold and runs very nice throughout the spectrum of demands. Fuel line is old school as noted in the picture.
PeterC is offline   Reply With Quote
Old 04-17-2015, 01:47 PM   #55
4ford
look at the air cleaner set up. here's the linkage I have...not so good... the air cleaners seem to work well.. like to find better linkage. question on the driver side of the carbs there's levers for throdell rods can you hook up linkage there also?
thanks
Old 04-17-2015, 02:02 PM   #56
scicala
scicala's Avatar
"It's not a good idea to remove your choke plate, even if you don't use the choke. Air flow studies have shown that these carbs flow less with the choke plates removed"
I worked 12 years on carburetor development and flow box work. I would love to witness that test or do it my self in order to believe it. Right now I don't.
The same air flow...., maybe. Less, I don't believe.
Sal
scicala is offline   Reply With Quote
Old 04-17-2015, 02:10 PM   #57
4ford
sal.
just taking some advice from some of the guys out there... kind of a backyard why of doing it. but there seems to be no difference with or with out the cleaners on??
Old 04-17-2015, 02:26 PM   #58
scicala
scicala's Avatar
4ford,
I've never done any flow box work with and without air cleaners. I would imagine most of the smaller air cleaners (dual and tri power type) are pretty restrictive. Especially the $10 ones you see. Would stay away from those all together. Use the taller ones with more filter area. It's hard to say about larger more quality type air cleaners. I would say on a flathead there would be very little or no restriction with a large air cleaner, especially the K&N type filters.
Sal
Old 04-17-2015, 04:28 PM   #59
4ford
its two filters put together and one is K&N wanted to see if it was working first b 4 getting 4 of them
Old 04-17-2015, 06:40 PM   #60
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I'm running 4 - 97's on my 276 in a 40 coupe. Direct linkage, I got the ball bearing linkage from Uncle Max, it works good, Walt
