Old 10-25-2010, 09:41 PM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default 1931 Widebed Pickup dispatch box & hood clip?
Should the hood clip on the top of the black truck radiator shell be painted, or is it nickel or cad plated? This is the retainer for the front of the top hood rod.
Does anyone know the exact location for the dispatch box on a 1931 Widebed Pickup? Dimensions from panel edge, etc. Thanks
Old 10-25-2010, 10:00 PM   #2
Charlie Stephens
Default Re: 1931 Widebed Pickup dispatch box & hood clip?
Tom,
Don't lnow. Maybe LeBaron Bonney, 800 221-5408, lebaronbonney.com, or Mack Products, (660) 263-7444, wwwmackhils.com would have the info. Post if you get an answer since I will have the same question for my narrow bed '31 RDPU.
Charlie Stephens
Old 10-25-2010, 11:19 PM   #3
james hitchcock
james hitchcock's Avatar
What exactly is a dispatch box ?
james hitchcock is offline   Reply With Quote
Old 10-25-2010, 11:36 PM   #4
Charlie Stephens
For a 1930-31 truck it is the open ended box installed on the passenger side cowl upholstery panel at about a 45 degree angle just under the gas tank. The truck driver stored his dispatch paperwork in this box. I don't know what they did in '28-29 open trucks but I think the dispatch box in the '28-'29 closed cab was near the drivers shoulder (please correct me if I am wrong as I don't know that much about the earlier trucks).
Charlie Stephens
Old 10-25-2010, 11:40 PM   #5
Brentwood Bob
Tom, Is the dispatch location the same as the early 31 small bed? I have a late feb ccpu, and can give you those dimensions. Bob
Brentwood Bob is offline   Reply With Quote
Old 10-25-2010, 11:41 PM   #6
james hitchcock
That's what I was figuring it was. I still have my original panel with dispatch box attached. I'll dig it out tomorrow, it's a bit rough panel wise but the box is in great shape. See if I can get some measurements and pic's posted.
Old 10-25-2010, 11:46 PM   #7
Gary WA
Gary WA's Avatar
Check out Bob Johnsons site www.modelahouse.com go to pictures other cars and the delivery with 174 pics has one I believe is the same location for pickups? its one of the interior pics you'll see it clearly pictured. goes at an angle .
Old 10-26-2010, 02:35 PM   #8
Philip McCarty
Chalie is correct. Passenger side panel under gas tank. I have a 31 WB and a 34 BB dump. It is mounted the same
Philip McCarty is offline   Reply With Quote
Old 10-26-2010, 03:41 PM   #9
Tom Wesenberg
Right, I knew where it was mounted, but was looking for the exact location, such as the bottom corner is x inches up from the floor and y inches from the door post, and the top rear corner is z inches from the door post. This would give me an exact location.
And I'm wondering about the front hood hinge retainer finish? Thanks
Old 10-26-2010, 07:16 PM   #10
james hitchcock
O.K I'll see if I can describe this cause I haven't been able to get a pic as of yet. Measuring from the firewall edge of the panel toward the post. The boxes top rear flange hole is 4 1/2" from the firewall. The top box flange corner lines up with the top of the panel where it curves under the gas tank. If I lay a straight edge where the cut out for the tank is it matches up with the top box edge. Is it clear as mud so far ? The hole in the lower flange closest to the door post is 3 1/4" from the panel edge. The lower hole on same flange is 7 1/4" from panel edge. Sorry these are the only reference points I have. Most of the panel is gone. Hope this helped somewhat.
Old 10-26-2010, 08:58 PM   #11
Bob C
Tom, try this http://forums.aa-fords.com/viewtopic...atch+box#p4107
Old 10-26-2010, 09:41 PM   #12
Brentwood Bob
Tom: on my original late Feb 1931 ccpu the measurements you asked for are as follows:
a. floor to very bottom of mounting flange(this is the corner of the dispatch box*) is 7 ".
b. from this point to the door post is 9".
c. horizontally from top right corner* of db to the door post is 3 1/4".
d. from top right corner to the floor is 11 3/8"(I added this).
I checked my huckster with a reproduction db on the kick panel. The measurements for it are:
a. 7 1/8"
b. 8 1/2"
c. 3"
d. 11 1/2".
* I measured from the corner of the box, not to the corner of the flange.Hope this gives you what you need. Bob
