Old 10-25-2010, 12:44 PM   #21
HoarseWhisperer
HoarseWhisperer's Avatar
Default Re: Sea Foam
Some sources indicate that fuel additives containing alcohol (as in Seafoam and some others), should not be used in Ethanol (alcohol) blended gasoline.
HoarseWhisperer is offline   Reply With Quote
Old 10-26-2010, 11:35 AM   #22
IronM
Sea Foam is good stuff, they also have a spray lube (think WD-40), that I have seen do some amazing stuff.
IronM is offline   Reply With Quote
