#21 |
"The needle bearing cage that was provided in the transmission rebuild kit was too long for the input main shaft and it pressed the input shaft forward a bit which didn't help with the engagement of third gear."
Are you using Ford PN A7063 the main shaft spacer ring? Tom Endy has cautioned about not forgetting this... Brattons and Snyders show that their shafts, gears, and roller caged bearings are USA made. Possibly others too but I do not have the catalogues
'31 180A |
#22 |
Yep, I used the main shaft spacer ring with Ford's original needle bearings. Mac's transmission kit didn't use the spacer ring as their needle bearings were too long to start with.
#23 |
Some shafts have the ring built in, so if you add an extra spacer ring, you could be in trouble.
#24 |
Wife cleaning the wheels! she is a keeper.
#25 |
#26 |
#27 |
Certainly glad to hear this!!
Did you notify the supplier that they sent you defective parts? "The needle bearing cage that was provided in the transmission rebuild kit was too long for the input main shaft and it pressed the input shaft forward a bit which didn't help with the engagement of third gear." you went thru a lot to figure this all out......
'31 180A |
#28 |
Good deal ! Maybe someone from Macs will read your fix !
#29 |
to bad you cant send in a labor reimbursement claim..
#30 |
Before blaming the kit, are you sure the kit came with 2 short bearings and 1 long bearing?
Short = A-7118 and long = A-7121 The cluster gear takes a short and a long bearing, and the input shaft takes the other short bearing. |
#31 |
i used the Mac's kit with no issues, and really glad I did - our transmission was almost entirely scrap! Luckily the case was fine - all the gears, shafts and bearings were well knackered, and I'd recently already rebuilt the shift tower anyway.
It's a joy to drive now, whereas before we were having issues with jumping out of 3rd at the most awkward of times, and prior to the shift tower rebuild, it was jumping out of second too.
Allan '29 Tudor, Canadian RHD Whangarei, NZ "Duct Tape can't fix stupid, but it can MUFFLE the sound" |
#32 | |
#33 | |
#34 |
friend out here in fla had this problem long story short ,, pilot bearing,, input shaft worn..he welded it up..turned it to specs on lathe ,installed and would not slip out again..hope input data helps..Charles..
)..ohh installed new pilot bearing.. )..
