Old 05-18-2010, 10:53 AM   #1
flathead30
Question weeping head bolt studs
got a few new head studs leaking, don't really want to remove the heads. added a bottle of stop leak, ran engine a few times, stopped a few leakers, any suggestions on getting them to dry up, thanks
flathead30 is offline   Reply With Quote
Old 05-18-2010, 11:09 AM   #2
Joe AZ
Joe AZ's Avatar
Default Re: weeping head bolt studs
Did you use sealant on the studs before you installed in block? Have heads been re-torqued after initial start-up? Just a couple of things to look at.
Joe
Joe AZ is offline   Reply With Quote
Old 05-18-2010, 11:23 AM   #3
flathead30
hi, thanks for the response, yes we used thread sealant on the block end of the studs, added a bottle of stop leak, ran engine for a few hours after, most of the leaks stopped, still have a few stubborn ones. also heads have been retorqued a total od 3 times so far.
Old 05-18-2010, 11:26 AM   #4
BOSSY
BOSSY's Avatar
Did you retorque the heads after you ran it a few times?
BOSSY
BOSSY is offline   Reply With Quote
Old 05-18-2010, 11:27 AM   #5
Bruce Lancaster
If new, they probably aren't stuck yet...
Find someone with a collet type stud puller and you can probably yank'em out from the top, put on the goo, and screw'em back in with heads on.
Old 05-18-2010, 11:44 AM   #6
Mick/mo
Mick/mo's Avatar
If it were mine I would run it for a long time before I would take anything apart, if it's just seeping. Mine seeped for several miles / days before it dried up.
Mick/mo is offline   Reply With Quote
Old 05-18-2010, 12:32 PM   #7
Kohnke Rebabbitting
Put a lead washer under each leaker, or all, retorque, what is the unused outside of the lead washer can then be peeled off, and you can't see they were used. Workes every time, as long as something isn't cracked. Make the lead washer is a good fit in the stud. Get sheet lead, or order from say McMaster-Carr, thanks Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 05-19-2010, 06:48 AM   #8
flathead30
Thanks for all the suggestions, and input. This site is awesome. Thanks again
Old 05-19-2010, 07:20 AM   #9
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
What type of sealer did you use?
Ross Murphy
1939 Ford Standard Coupe
Ross in East Texas is offline   Reply With Quote
Old 05-19-2010, 11:45 AM   #10
FRANK PKNY
FRANK PKNY's Avatar
Just run it it will stop in time . Common problem not to worry. Frank
FRANK PKNY is offline   Reply With Quote
Old 05-19-2010, 12:43 PM   #11
Pete
What he said.....They WILL stop in due time.
Old 05-19-2010, 01:14 PM   #12
OLD...BILL
OLD...BILL's Avatar
Left over from the "Old Barn" put an "O" ring on the stud,. under the nut, add some (goop) sealer, run it and retorque.
OLD...BILL is offline   Reply With Quote
Old 05-19-2010, 04:57 PM   #13
joe plumber
The leaks will stop ,mine did the same thing.Nothing to worry about
joe plumber is offline   Reply With Quote
Old 05-19-2010, 05:09 PM   #14
mike in las vegas
mike in las vegas's Avatar
I'm with frank and mick. Time will stop with all te procedures metioned
mike in las vegas is offline   Reply With Quote
Old 05-19-2010, 07:09 PM   #15
Bob/Ohio
Bob/Ohio's Avatar
I used a good quality brush type teflon pipe dope, but make sure you get one that is rated for at least 200 degrees, not all of them are.
Bob/Ohio is offline   Reply With Quote
Old 05-20-2010, 08:45 AM   #16
Krylon32
I always add a bottle of Alumiseal after the motor warms up after the second head torque. It has stopped most of the leakers after some miles. Them pesky leakers that don't stop have to be removed and resealed, kind of a pain in the ass, but got to keep those heads prestine.
Krylon32 is online now   Reply With Quote
Old 05-21-2010, 10:27 PM   #17
john stimac
john stimac's Avatar
Drain and flush everything thoroughly,add water only, run at idle for half hour,add MOROSO sealer, about 15 bucks a can into system, run for one hour, drain and add water and soluble oil good to go.
Stimac
john stimac is offline   Reply With Quote
