Old 12-24-2014, 11:20 AM   #1
Patrick L.
Patrick L.'s Avatar
Default Radial tires
Has anyone found and used radial tires ? Good or bad ?
Old 12-24-2014, 12:46 PM   #2
Big hammer
Default Re: Radial tires
Their pricy Work good on modern cars Don't know about on A's
Old 12-24-2014, 12:48 PM   #3
CarlG
CarlG's Avatar
A lot of guys here are using radials. Mostly 16 inchers. They seem to like them. I'm holding out till I can afford a set of 19 inchers.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-24-2014, 01:00 PM   #4
Patrick L.
Patrick L.'s Avatar
I haven't found any 19s yet. Must not be looking in the right places.
Old 12-24-2014, 01:12 PM   #5
Big hammer
Try Coker Tire for one Macs I think
Old 12-24-2014, 05:23 PM   #6
mhsprecher
mhsprecher's Avatar
Other threads here have been very positive about them. 19 inchers, I thought.
mhsprecher is offline   Reply With Quote
Old 12-24-2014, 08:35 PM   #7
Tierod_Bill
Tierod_Bill's Avatar
I have COKER's so far so good....
Tierod_Bill is offline   Reply With Quote
Old 12-25-2014, 10:25 AM   #8
Paul from Maine
Paul from Maine's Avatar
If you drive a lot, switch to radials! The difference in ride, handling and braking is like the difference between night and day! I had four 15" Jeep rims lying around and just for fun bought two Goodyear Wranglers from Walmart and bolted them on the rear! What a difference! I then ordered new cast iron brake drums for the front (the studs are too short for both a wheel spacer and rim), installed longer studs and mounted two more Wranglers on the front! Even though the car is stock and the radials make it look like a hot rod, I will never go back to bias ply! I have already found two 16" wire V8 wheels and when I find two more I will put 16" radials on the car!
Paul from Maine is offline   Reply With Quote
Old 12-25-2014, 10:50 AM   #9
JohnLaVoy
JohnLaVoy's Avatar
Coker Tire sells both 19" and 21" steel belted radial tires. The Roadster Pickup was the first car we did and then put them on a 29 sedan to see the 21" size both work very well. They don't make them in White Wall yet.
JohnLaVoy is offline   Reply With Quote
Old 12-26-2014, 01:09 AM   #10
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Do you use inner tubes?
Old 12-26-2014, 01:47 AM   #11
SDJason
SDJason's Avatar
Originally Posted by JohnLaVoy View Post
Coker Tire sells both 19" and 21" steel belted radial tires...
Are these the ones (made by Excelsior)?
SDJason is offline   Reply With Quote
Old 12-26-2014, 10:28 AM   #12
Patrick L.
Patrick L.'s Avatar
They were right there, I didn't look far enough.
My main question was how they were liked or disliked. Apparently everyone likes them, thats good to know.
I remember how terrible some of the cars in the 50s and 60s handled and rode, and when radials came out how big a difference they made in them.
Old 12-26-2014, 11:08 AM   #13
JohnLaVoy
JohnLaVoy's Avatar
Yes, to inner tubes and Excelsior.
Old 12-26-2014, 11:09 AM   #14
JohnLaVoy
JohnLaVoy's Avatar
We like the ride quality, and because we put so many miles on a car the tread wear warranty of 50,000 miles is very nice. You would have to buy the regular tires two and a half times to get that much wear.
Old 12-26-2014, 12:02 PM   #15
steve s
steve s's Avatar
John,
How do the rolling diameters compare for the 21" radials vs. stock?
steve s is offline   Reply With Quote
Old 12-26-2014, 12:13 PM   #16
JohnLaVoy
JohnLaVoy's Avatar
It is a little larger, but don't recall the exact dimensions and that car is stored at the ranch so won't see it for a few days. These tires are a little larger than the Goodyear 450-21" but because they were put on a fordor sedan they work well. You also get a little more tread on the ground because they are a little wider than the original. I did get it into the fender well on the roadster pickup but it is a squeeze.
Old 12-26-2014, 11:08 PM   #17
ian Simpson
Did you use radial tyre specific tubes? There used to be different tubes for radial and bias tyres.
ian Simpson is offline   Reply With Quote
Old 12-26-2014, 11:30 PM   #18
JohnLaVoy
JohnLaVoy's Avatar
Yes, got the tubes from Coker when I ordered the tires. Very nice tubes with metal valve stems and they are radial tubes.
Old 12-27-2014, 12:04 AM   #19
Tom Wesenberg
Tom Wesenberg's Avatar
Does anyone know how the radial inner tubes differ from bias tubes? Thanks
Old 12-27-2014, 11:39 AM   #20
1931 flamingo
1931 flamingo's Avatar
Summitt offers free shipping, possibly Jeg's also. Both handle Excelsior.
Paul in CT
