#21 |
The shipping cost is not the cost of the stamps that is expensive but the labor to put it in the envelope. It also adds to the bottom line. I try to wait until I have a bunch of things to order so that shipping cost can be combined.
#22 |
#23 |
Model A 1929
I was always told DO NOT TURN MOTOR OVER WITH THE FAN. That is one of the most likely causes of Fan cracking and blade failure. Crank it or use a wrench on the crank nut. I am always tempted to try and nudge it one way or the other with the fan blade, but have resisted...Have not lost a fan blade yet. |
#24 |
I don’t know that I would try to use the fan to turn a motor against compression, but if the plugs are out you absolutely can use the fan. Won’t hurt it a bit.
#25 | |
#26 |
With the plugs out the engine is so easy to turn even if you use the fan belt to turn it. BTW , you can legally mail a potato through the USPS by writing a mailing to and return address with a sharpie and a few stamps. It’s recommended you take it in the post office for actual weight though. |
#27 |
I've seen bananas mailed that way, the first postal employee in line smiles & the last one goes "UGH".
#28 |
Our post office has an addressed flip-flop on display.
#29 |
Why aren't they delivering it?
#30 |
#31 |
After reading this post about the "quick point gap setter" I went out to my shop and machined one with my lathe, then milled the needed feeler gage, and it works ok.
#32 |
#33 |
Here ya go: https://www.homemadetools.net/forum/
#34 | |
#35 |
Machine shop time is now about @80 per hour. So if you like making tools in your machine shop then go for it. Otherwise it is usually less expensive to buy them.
| Thread Tools | |
| Display Modes | |
