Old 12-16-2021, 07:33 PM   #1
alanwoodieman
Default eab vs 8ba heads
what if any advantage of eab heads on an otherwise 8ba stock engine 3 3/4 stroke
Old 12-16-2021, 07:50 PM   #2
tubman
tubman's Avatar
Default Re: eab vs 8ba heads
If all components are up to the proper specifications, the change should increase the compression ratio from 6.8:1 to 7.2:1.
Old 12-16-2021, 11:37 PM   #3
Newc
Newc's Avatar
I understand that EAB are the heads to use, much better than the Merc heads..and in the OLD days I pitched them for the Mercs!!!!Newc
Old 12-17-2021, 06:01 AM   #4
jimvette59
jimvette59's Avatar
tubman what is the difference between the Merc EAC headsand the EAB heads ?
jimvette59 is offline   Reply With Quote
Old 12-17-2021, 08:14 AM   #5
Zeke3
Zeke3's Avatar
The Merc EAC heads have a larger combustion chamber than the Ford EAB heads, EAC=75-77 cc and EAB=70-72 cc.
Zeke3 is offline   Reply With Quote
Old 12-17-2021, 08:26 AM   #6
alanwoodieman
as always, I knew the answer to my question was here, thanks!
Old 12-17-2021, 10:56 AM   #7
Ol' Ron
Ol' Ron's Avatar
And you can angle mill them .070" and get 64cc, I think???
G
Old 12-17-2021, 11:02 AM   #8
rotorwrench
rotorwrench's Avatar
FoMoCo wanted the 255 to have the same compression ratio as the 239 and the only way to do that was increase the clearance volume.
Old 12-17-2021, 03:17 PM   #9
51504bat
51504bat's Avatar
Funny how some people use Merc heads on an 8ba with a 3 3/4" crank thinking that Merc heads mean better performance. Not.
Old 12-17-2021, 03:22 PM   #10
JWL
8BA heads, when milled .050, deliver almost identical C.R. as EAB heads. However, there is also a small difference in the transfer area design.
JWL is offline   Reply With Quote
Old 12-17-2021, 09:16 PM   #11
Ol' Ron
Ol' Ron's Avatar
When I was doing my Flow bench work I made up a wooden head and with all kinds of combustion chambers and tested them all looking for the "Holy grail" of flow The transfer area is interesting, by changing the angle of it it increased flow untill about 12 degrees, Unfortunately the castings were too thin for this angle so I use the Offy heads (thicker casting) to make my chambers and use an 8 deg transfer angle. un fortunately this reduces the CR some. Every little bit helps.
Gramps
