Old 07-11-2020, 06:28 PM   #1
46woodie
Default Installing stainless trim on 46 runningboards
Ok,I've used half a bottle dishwashing soap to help slide this stainless on. It will go 10-12 inches and it stops. Rubber feels smooth but may try some 320 sandpaper with detergent to smooth it more tomorrow. Any suggestions???
Thanks
46woodie is offline   Reply With Quote
Old 07-11-2020, 07:38 PM   #2
Gary in La.
Gary in La.'s Avatar
Default Re: Installing stainless trim on 46 runningboards
I never have slid them on. Usually line them up on the length of the board and slap (press) them in place. They will snap in place with out too much force. This was done on NOS running boards and NOS trim. This may have made a difference.
Gary in La. is offline   Reply With Quote
Old 07-11-2020, 08:36 PM   #3
46woodie
THANK YOU!!! I have been sitting here thinking about doing that tomorrow. Makes sense but didnt know if I would be able to pull it up on top of board once it was latched on lip(bottom edge of board). Thanks for the advice
Old 07-12-2020, 09:25 AM   #4
oldford2
oldford2's Avatar
Thanks
I must be missing something. I cannot figure out how you could slide them on since both ends butt up to the fenders. I do know they snap on. I did one years ago and cannot remember the process. I do remember it was not easy. Forgot whether to hook the top or bottom on first and then snap on.
I guess this doesn't help much.
John
oldford2 is offline   Reply With Quote
Old 07-12-2020, 10:54 AM   #5
johnny
Suggest hooking trim on bottom lift up hard and at the same time snap the top onto the board .use the palm of your hand , lift and snap. might not hurt to spray cilicone on rubber first
johnny is offline   Reply With Quote
Old 07-12-2020, 11:06 AM   #6
woodiewagon46
Yup, like Gary and Johnny mention.
woodiewagon46 is offline   Reply With Quote
Old 07-12-2020, 12:26 PM   #7
46woodie
I should have mentioned,they are off the car. Thanks again,will have em on later today!!
Old 07-12-2020, 06:18 PM   #8
Marvin/TN
Send a message via AIM to Marvin/TN
If you use silcone I hope you don't plane to do any paint work on the car. You will regret
using it if you do. This is comming from someone that had done collision repair and painting for over 50 years and a collision repair shop owner for over 45 years. I did not allow silcone either inside my shop or outside of it.
Marvin/TN is offline   Reply With Quote
Old 07-12-2020, 07:53 PM   #9
46woodie
No silicone,dishwashing soap. Worked great,job done. Thanks guys
Old 07-06-2023, 05:11 PM   #10
r-horn
Hi 46woodie, I'll be tackling my runningboards this Fall and would love to pick your brain and learn from your experience. I have a 46 woodie also. Are you in the NWClub member directory?
r-horn is offline   Reply With Quote
Old 07-06-2023, 07:17 PM   #11
woodiewagon46
r-horn, if you're located in the north east the NWC Nationals will be held at the Mystic Seaport in CT the weekend of July 22nd. Should be 50 to 75 Woodies.
Old 07-06-2023, 08:46 PM   #12
r-horn
Hi woodiewagon46, I'm located on the west coast and we just held Woodies on the Wharf. Attendance was around 145 cars, down from the usual 170ish. It was a beautiful day with beautiful cars, and the people weren't bad either. I hope you have a good show at Mystic. I've attached a couple photos from WOW.
Old 07-06-2023, 08:59 PM   #13
petehoovie
petehoovie's Avatar
