I just found 3 n.o.s. mallory distributors with some old model t parts. Did mallory make distributors for model t's? What are they worth?
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/ |
Typically Mallorys first unit for the early Fords was for the model A engine. Load up a couple picture of what you have and we will try to get you a appliction.
The Ts front cover never supported a distributor without a external gear drive of some kind... |
I have acquired the model t mallory distributors, . They are n.o.s. parts
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/ Last edited by 32forddump; 02-07-2013 at 07:04 PM. Reason: policy |
#4 | |
The front mount model t distributor is a great item, however the drive gears are pretty hard to find. |
Thats a raised timer not a distributor. Look at the drive gear... is it a 45 degree bevel or a counter mesh helical? Pull the cap and I think youll just find a contactor (timers are a grounding timing device) that makes contact with the cap. Post some pics of the guts and gears... I wonder what the rheostat on the cap is for??? ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!" |
Thats pretty bizarre! The cap looks like a new day timer (plastic/bakelite with a spring loaded brush) yet theres a set of points (minus the condenser). Hmmm. That may be a dual purpose distributor / timer. The timer for running on the 32 VAC Magneto and the points for a single 6 VDC coil for easier starting.
I think that if the large brass contacts were used with a high voltage coil they wouldnt hold up. The dwell would also be immense, no? I wonder if that rheostat sets the contact pressure on the rotor/contactor. Is there any evidence of a coil inside the large square part of the frame of the unit like maybe its a self contained magneto? BUBBA's gonna need to pipe up on this one! Got the cam end gear to drive it? ws
I have a bag with several gears, iam going to try to fit it on engine today.
This looks like a distributor with the coil & likely the condenser built in to the box affair which is part of the casting. The cap is similir in design to the early Delco caps used on pre-teens Cadillac 4 cylinder cars. The rotor has a carbon brush that connects the center electrode to the respective plug wires as it turns. The rheostat looking thing is likely a spark intensifier of sorts. The dwell would not be altered by the wide cap contacts, the width assures contact throughout the spark advance movement - avoiding any degree of arking is important with this set up. The dwell is controlled by the point setting.
Below is a DELCO cap for a 1911 Cadillac; ( I need one & a rotor if anyone has anything like this)
Jack Innes, Brooklin, Ontario |
I wonder he New Day timer just fit, and someone stuck it on there?
That's an original period correct e-timer.
I was able to put the gear that i had on the camshaft this morning and it fit well.
#13 |
I bought a book years ago from Don.Lang. On after market parts for the model T Ford.
It was made up from old ads back then. If some one has that book. I'am sure that. That distributor would be in it. I let a guy use mine and that was the last I saw of it. This book was about the same size. As the Model T Service Manual. |
#14 |
If I recall it's resistance coil and was used in conjunction with a Model T coil. Many clip on distributors were able to be setup with ether a normal coil or a Model T coil.
#15 |
Iam going to hook up timer to a batttery today to see if it functions.
#16 |
You will need a coil to check it out. The box on the front is the condenser.
#17 |
FWIW... I wouldnt use that cam gear! It looks like die cast pot metal. Take it to a gear shop as a template and get a steel gear made. It looks too good to take a chance with! HONEST!! ws
#18 |
So are you saying that I should have both gears remade out of steel?
#19 |
Thanksyou for the advice. Iam going to try to make it function today,I will hook it up to a battery and coil to see if I can get the points to spark.
#20 |
The points only carry line voltage, 6 or 12 volts. Did you mean, spark at the plugs? Make sure the points are clean and grease free and go for it!
