Old 12-01-2024, 09:27 AM   #1
Bullerman
Default Heater in 50 model custom
My next project. The heater in my 50 model isn't hooked up. The wire is hanging.it has been converted to 12 v.
I bought a resistor to go from 12 to 6 volts. Can I put the resistor on this wire and go straight to the battery to see if the motor works before I hook it all up to the switch.
The guy added a extra fuse panel under the dash. I should be able to put the fuse between the motor and fuse panel then go from the panel to the switch .
I am terrible on electrical stuff. Starting to get cold.
Bullerman is offline   Reply With Quote
Old 12-01-2024, 10:49 AM   #2
Zeke3
Zeke3's Avatar
Default Re: Heater in 50 model custom
I did exactly what you are suggesting, to add a resistor in the power line to the heater, when I converted a car from 6v to 12v. I don’t remember being concerned with the polarity change. That was a long time ago.
Zeke3 is offline   Reply With Quote
Old 12-01-2024, 11:37 AM   #3
GB SISSON
GB SISSON's Avatar
Not a long time ago for me, I did just that yesterday morning. Actually I installed a two speed switch and only ran it on the low setting. I will be watching this thread as the lower speed was a bit anemic and the high speed was like 'blast-off'. Hoping to find a resistor that makes high speed useable. Not sure I like glowing coils under the dash, but what's out there?
Old 12-01-2024, 12:46 PM   #4
Bullerman
No luck. I unplugged the heater wire. I connected the resistor to that and went to the positive battery post. It sparked like it was a direct short.
I was just trying to see if the motor runs. What did of resistor did you use. Probably will have to go to somebody that knows what they are doing. Wish I had a 6volt battery to hook up to it.
Old 12-01-2024, 01:03 PM   #5
tubman
tubman's Avatar
Do you have a battery charger with a 6 volt setting? I have used that in a pinch.
Old 12-06-2024, 08:43 AM   #6
Bullerman
You just used the 6v battery and hooked it directly to the two wires on the motor. I have to fix the ground wire on the motor. I was going to just take it out. Don't know if I should try and just take the motor or the parts the motor is mounted to. I need to make sure it works or not.
Old 12-01-2024, 01:42 PM   #7
Cecil/WV
Cecil/WV's Avatar
Try it with 12v and see if it will run, just do not leave it on long. that will tell if the motor is good.
Cecil/WV is offline   Reply With Quote
Old 12-01-2024, 03:07 PM   #8
GB SISSON
GB SISSON's Avatar
Does the fan spin freely?
Old 12-01-2024, 06:17 PM   #9
Joe B.
Joe B.'s Avatar
6 volt lantern battery should spin it. The motor and cage are easily removable. I had mine out and apart a year ago. It needed a new feed wire.
thread killer
Joe B. is offline   Reply With Quote
Old 12-01-2024, 06:47 PM   #10
Bullerman
I need to pull it out like you said and if it spins freely. I can get a 6v lantern battery like you said. I hadn't thought about that.
I think I would actually like to hook it up with a separate off/on switch. Just bypass all the stock wiring. Would that be and idea?
Old 12-02-2024, 08:56 AM   #11
Joe B.
Joe B.'s Avatar
The stock setup is a short fused wire from heater sw to to the ignition sw, wire from heater sw to motor, and wire from motor to firewall ground, When I redid mine, I put a small grommeted hole through the firewall (pic) and ran the wire under the dash instead of across the engine compartment and through the main wiring grommet like the stock setup.
thread killer
Old 12-02-2024, 09:43 AM   #12
pistonbroke
I found that polarity matters in heater motors when my brother put the new battery in my 36 dodge backwards. The heater motor made bad noises and didn't blow at all. Every thing els worked for a time. If I was the original poster and was taking the heater out, I would simply buy a 12 volt blower motor that fits the heater. Tim
Old 12-02-2024, 10:01 AM   #13
mcgarrett
Can you describe or post a photo of the resistor you plan to use? An ordinary ignition resistor will not work for this kind of duty.
Old 12-06-2024, 12:12 PM   #14
flatford8
flatford8's Avatar
I’d pull the motor out. It’s just 5-6 screws around it. I’ve found it usually needs a cleaning in the heater box. Then you can work on the blower motor ……..Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 12-08-2024, 08:46 PM   #15
Bullerman
The motor will come out taking the 5 or 6 screws out with the squirrel cage blower on it.
Is there a secret to getting those screws out.
Old 12-09-2024, 11:13 PM   #16
Joe B.
Joe B.'s Avatar
No they are just small sheet metal screws with a 1/4" hex head IIRC.
thread killer
Old 12-10-2024, 09:59 AM   #17
Shoebox
Shoebox's Avatar
I went through the same thing when changing from 6v-12v on my "51. Use the 12v motor from Shoebox Central and swapped the squirrel cage. Works nice.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 12-08-2024, 09:25 AM   #18
Bullerman
I went ahead and ordered a 12v fan motor from Shoe Box Central. Still going to hook it up separate with it's own switch.
I hope the rest of the system works. All the levers seem to slide back and forth. I am not sure about the heater control valve. I know water was circulating through the heater core. I assure the control valve determines how much water goes through the core for heat.
Don't really know what goes wrong with the heater control valve unless it leaks or is froze up. Looks like the two main parts to go wrong are the motor and the heater control valve.
Old 12-08-2024, 09:47 AM   #19
flatford8
flatford8's Avatar
Right, the valve controls the flow or shuts it off. As long as your heater core isn’t plugged, you should get heat…….Mark
Old 12-08-2024, 11:32 AM   #20
Bullerman
I don't think it is because it was burning us up when it was hot. Can I take the hoses off of it and run water through it to make sure it isn't stopped up.
Guess I could take the return hose off and crank the car and see if it's pushing water through it.
