10-24-2023, 03:35 PM | #1 |
1941 PickUp Cab Heater
I just put a note in the Wanted section for a 1941 PickUp Cab Heater.
If anybody has one, or the necessary parts to re-manufacture one, I'd appreciate it. Also anything for the defrosters. I'm looking in the "bay", but all I find are either 1941 Car heaters, or 1939-40 and 1942 to ??. Nothing in the 41 PickUp. Thanks Mike |
10-24-2023, 08:55 PM | #2 |
Re: 1941 PickUp Cab Heater
My 40/41 big truck came with a 'car' heater. Looks factory. Newc
10-24-2023, 09:51 PM | #3 |
What would a pick up heater look like?
Certainly, the 48-52 vintage had fresh air styles. Not sure what is period correct for pre-war.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
10-24-2023, 10:34 PM | #4 |
Starting in '39 I believe both hot air and hot water were available.
We might have a hot air setup. There should be something like a knockout visible from the engine compartment at the top middle of the firewall where the register mounts. PM me if you are interested and we can look at our stock. If you are interested in hot water I can point you to Larry who deals in those. -Scott |
10-25-2023, 09:08 AM | #5 |
The truck heaters were different than the passenger cars. Many, perhaps most, do not realize this.
The truck heaters have the water nipples located differently than the passenger cars and have a drain valve, unlike the passenger cars. They (truck heaters) are scarce. I am quite certain hot air heaters were NOT offered for the trucks.
10-25-2023, 09:54 AM | #6 |
1939mars: I'm not sure who "Larry" is. Could you give me more information Mike |
10-25-2023, 11:08 AM | #7 |
Yes, correct, the water tubes. They must be in a different location to fit the vast differences of the truck vs. passenger car dash panels (firewall) designs.
10-25-2023, 11:14 AM | #8 |
Kube: Can you send me a photo of the difference?
If not, can you explain what the difference is? I've seen heaters with the water nipples on the opposite side of the core and diagonal in the height. I've also seen them right next to each other and on the same side of the core. Thanks Mike |
10-25-2023, 12:59 PM | #9 | |
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 10-25-2023 at 04:14 PM. |
10-25-2023, 09:38 PM | #10 |
10-25-2023, 09:54 PM | #11 |
RBRanche: PM sent.
1939mars: PM sent. Kube: Thanks for the Photo. |
10-25-2023, 09:37 PM | #12 |
I do have this Parts and Accessories letter that calls out an 11T-18455-B assembly which indicates that it was made for a '41 big truck. I have never actually seen one or an installation drawing.
10-25-2023, 12:20 PM | #13 |
I have a Southwind Gas heater in my PU. I love it. I have an extra one as well if interested.
10-25-2023, 12:54 PM | #14 |
If the intent is to build a concourse correct vehicle then you are stuck trying to find a factory correct heater as described by Kube. However, for all practical purposes a car heater would do the job, most people would never know the difference.
My 36 Ford had a '39-40 heater in it when I bought the car in 1952. In the 71 years that I have owned the car, nobody has ever mentioned that the heater is not correct for the car.
Bill.... 36 5 win cpe |
10-26-2023, 07:58 AM | #15 |
41 Ford Truck Heater. See attached
10-26-2023, 11:10 AM | #16 |
10-27-2023, 09:00 AM | #17 |
That's the same unit in my '46 Tudor. Most heaters were dealer installed options and thus were widely varied in practice.
The 'Ford' script freash air heater was also found in many 48-50 F series trucks..
10-27-2023, 10:53 AM | #18 | |
10-28-2023, 05:22 PM | #19 |
I've found that there is a difference between the control switches.
The first and obvious one is the color. I've seen about four different colors. There was Grey, and Cream. There where also some variation in the tone of the colors. A whiteish cream and a whiteish grey. The next difference was in the lettering of them. One is: Defrost - Off - Heat. The other is: Indirect - Off - Direct. All of them are listed as 1940 to 1948. They all had the lettering in Red. I'm also having trouble finding a One Hole mounting bracket. I've seen a few Two Hole ones. All of this information came from the "bay". Not the most reliable of sources. Any guidance would be appreciated. Mike |
10-26-2023, 12:44 PM | #20 |
Mike: I have a heater for sale that I just removed from my 41 Pickup. Fan works when I connected to battery and there were no detectable leaks when I removed it. Will gladly send you pictures as well as answer and questions you may have. Please advise me of your contact info.
Thanks |
