I may have posted this question in another one of my posts, a different subject; so let me post it again under the "correct" subject.
New to the "Y Block" engine; and in checking over this recently obtained 54 Customline; I noticed (since on this Ford the distributor is in the rear) the spark plug wires running behind the engine. On my 54 the wires were running, coming into contact with the carb linkage; just didn't look correct. I did some "gathering", utilizing the "zip tie plug holder" system, and somewhat gathered and lifted them away from the linkage. Q. Does Anyone have a good pic, drawing, or schematic as to how those wires run, any clamps needed, etc.: |
Here are some pics from an old post on the Y-blocks Forever forum. There are several clamps and they all need to be there mainly to keep the plug wires from contacting the exhaust manifolds, and to provide separation to prevent cross firing. Installing the clamps and routing the wires with the engine in the car can be a PITA but worth the effort. The clamps are available from most classic Ford parts suppliers.
http://forums.y-blocksforever.com/Topic138933.aspx
Often wrong but never in doubt. |
Many things to love about this engine. Plug wire paths aren't any of them.
Years ago, I inherited my mom's 312 '57 T-bird she bought new, it still had the original plug wires. Those were the worst wires I ever had to put on an engine running behind those heads, and I had to stand stood on my head in big truck engine compartments replacing them.
This is how they are supposed to be. All the brackets are available, some vendors have wires and brackets all assembled and ready to install.
Some of the repro parts suppliers offer a kit that includes all the brackets with their rubber grommets for the plug wires. They also offer OEM style plug wire sets for Y-blocks.
Look at Dennis Carpenter, Mac's or Concours. Many others. It's a good idea NOT to eliminate the use of the OEM style brackets. Those help keep heat away from plug wires especially running under exhaust manifolds. |
