Old 07-05-2022, 09:54 AM   #1
19Fordy
19Fordy's Avatar
Default My COIL EXPLODED
Car wouldn't start. Checked the coil and discovered the top plastic part had actually lifted out of the case. Never had that happen before. The ignition is 12V with Pertronix kit and matching coil. It has worked fine in the past. Coil is the oil filled Pertronix unit shown here:
https://www.amazon.com/PerTronix-400...a-568782789506
I suspect that the engine compartment heat caused the coil failure.
Would installing an aluminum coil cover like the ones shown below dissipate enough heat to protect the coil from overheating?
https://www.google.com/search?q=flat...client=gws-wiz
Or would it be better to wrap the coil in aluminum foil and foam insulation material. The coil is mounted on an aluminum bracket attached to a water pump bolt so radiator fan blows air on it. Should I relocate the coil?
Opinions welcome.
Old 07-05-2022, 10:03 AM   #2
tubman
tubman's Avatar
Default Re: My COIL EXPLODED
You probably don't want to hear my answer.
Old 07-05-2022, 10:04 AM   #3
Lawson Cox
Lawson Cox's Avatar
Go back to stock and get a Skip Haney coil. My 2¢
Old 07-05-2022, 01:29 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
It is clearly evident, as shown in 19Fordy's enclosed picture, that he is running an 8BA-type engine, ALL of which use the more modern, upright distributors. Even more applicable to this thread, it is also easy to see that these ignition systems use a can-type coil which is mounted adjacent to the distributor, which is the STOCK location for an 8BA engine. SKIP HANEY does not rebuild the 8BA-type coils. Your 2¢ not good today. Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 07-05-2022, 03:56 PM   #5
Lawson Cox
Lawson Cox's Avatar
I can't be right ALL the time Coop. LOL
Old 07-05-2022, 04:10 PM   #6
ford38v8
ford38v8's Avatar
Lawson, my wife bought me a coffee cup she said would fit me just fine. Emblazoned on it in big letters: MR. RIGHT.
Alan
Old 07-05-2022, 10:06 AM   #7
JayChicago
JayChicago's Avatar
Or maybe an internal short caused the excessive heat. Why not just replace the coil? Probably will never happen again. Maybe replace with a regular coil cuz your flathead can never make use of that 40,000 volt boy-racer coil.
Old 07-05-2022, 10:10 AM   #8
19Fordy
19Fordy's Avatar
Thanks for the answers. I know Tubman is a points only guy.
The distributor is a Mallory dual point with mechanical advance so I could go back to points.
Who makes good high quality points?
Old 07-13-2022, 02:02 PM   #9
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
As tub man stated you probably dont want to hear my answer so i will make it short . The perronixs coils have a problem . resistance isnt correct and often wrong coil ( low resistanceZ) is sold to customer then key is left on cil heats up with high amps ..........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 07-13-2022, 02:26 PM   #10
tubman
tubman's Avatar
There are two possible sources. The first is original Mallory points. I have found them on eBay for $20 to $25 new. You usually only have to replace the trailing points pair, as they are the ones that usually transfer material. Check the points before replacing them.
Secondly, NAPA has Echlin points that are a direct replacement for the original Mallory points. For example, Echlin CS754 points from NAPA are a functional replacement for the Mallory 24875 points. I have found other equivalences, but don't have them handy. if you can get the numbers off the original points, I may be able to match them up.
I have never had a problem with Echlin points.
Old 07-05-2022, 10:10 AM   #11
TJ
TJ's Avatar
I had two of those fail in the last year. Won't buy any more and know others who have had problems also.
Old 07-05-2022, 10:13 AM   #12
tubman
tubman's Avatar
Bosch Blue Coil?
Old 07-05-2022, 10:17 AM   #13
19Fordy
19Fordy's Avatar
Originally Posted by tubman View Post
Bosch Blue Coil?
No it's not a BOSCH Blue coil. It's the Pertronix coil 40001 that matches the Pertronix conversion kit.
Old 07-05-2022, 10:22 AM   #14
tubman
tubman's Avatar
I understand that; I was proposing a solution.
Old 07-05-2022, 03:47 PM   #15
drolston
drolston's Avatar
Bosch Blue Coil?
Ditto on Bosch Blue. Probably a fluke that the Pertronix coil failed. They are a good product but overkill for a flathead.
Old 07-05-2022, 10:32 AM   #16
19Fordy
19Fordy's Avatar
tubman, Thanks. I appreciate your suggestions and knowledge. Here's some interesting about BOSCH BLUE COILs.
https://vwparts.aircooled.net/12V-Bo...p/00-012us.htm
When I bought the Pertronix kit (ML-181)it came with the Pertronix coil # 40001 with 1.5 ohm primary resistance. I not using a condenser or a ballast resistor.
My distributor is a Mallory YL 2527501 Series 25 dual point unit converted to a Pertronix using their ML-181 kit. Pertronix told me to use their Flamethrower 1.5 ohm coil, not the 3 ohm coil.
The more I read, the more confused I get about what coil is the correct coil to use with my Pertronix.
Additional thoughts welcomed with open arms.
Thanks, JIM
Old 07-05-2022, 11:06 AM   #17
Tim Ayers
Thanks, JIM
My understanding is Petronix needs a 1.5 ohm coil. I would suggest calling their help line if you are unsure. I've found then to be very helpful.
Old 07-05-2022, 10:42 AM   #18
tubman
tubman's Avatar
All I know is that I purchased one when they were on special for my engine test stand. (Most of the engines I test run are 12 volts.) It has worked fine for me.
Old 07-05-2022, 10:50 AM   #19
sidevalve8ba
sidevalve8ba's Avatar
Check on Ebay for the Bosch coils. Sometimes you can find a deal on there for them. But like almost everything else, I am sure they have probably gone up!
sidevalve8ba is offline   Reply With Quote
Old 07-05-2022, 10:51 AM   #20
Bored&Stroked
Bored&Stroked's Avatar
Looks to me like you have it in a place where plenty of air can get to it . . . so, I'd probably just buy 2 replacement coils and keep one in the trunk.
As it is matched to the Pertronix ignition (their recommendation) - would run what they recommend, otherwise you may experience other issues (like a failed ignition component).
