Old 05-14-2022, 08:54 PM   #1
miwi
miwi's Avatar
Default Nessary spare parts for 1500 miles trip
I‘m going to do a 1500 mile plus trip through Germany, Belgium, France and Great Britain with my F1. I‘m thinking about what kind of spare parts should I carry with me in case of a breakdown. I have a 239 french block with dual carbs and a Bubba distributor.
My current list includes:
Head gaskets
Fuel pump
Fan belt
Spark plugs
Blubs
Throttle cable
Fuel line
Engine oil
Transmission oil
Differential oil
Anything else that I should carry with me?
miwi is offline   Reply With Quote
Old 05-14-2022, 09:04 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Nessary spare parts for 1500 miles trip
You should be able to get all oils, bulbs, fan belt, spark plugs, fuel line/filter, electric fuel pump, hoses, in those countries, so you shouldn't need to drag those along. Good tools should be carried. A thorough inspection will usually keep you from breaking down. Take pleanty of money for gasoline!
Old 05-16-2022, 12:50 AM   #3
Karl
Karl's Avatar
I agree -AA card and cellphone . I used to carry almost everything ,
Now I have it all assemled on the bench in the garage . I take a cell phone picture of it all and leave a key with a trusted friend - In the unlikley event of a breakdown -My friend will have what I need to me within 24 hours by express courier. The cellphone picture makes sure he sends me what I need ie third from right -Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 05-14-2022, 09:06 PM   #4
aussie merc
aussie merc's Avatar
only doing 1500 not 15000 so if every things good a set of belts a fuel filter and maybe a set of points and a condenser anything else i would think twice about going at all
aussie merc is offline   Reply With Quote
Old 05-14-2022, 09:08 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
Depending on type of ignition, I'd have a spare set of points, a condenser, cap and rotor. You might also think about radiator hoses and a set of hose clamps (multiple sizes). Brake fluid as well. Also, rags, jack stands, good jack, something to lay on (like a sheet of cardboard) and a really good LED flashlight - one that can stand up on its own and be directed (think working under the car at night on the side of the road!).
Old 05-14-2022, 09:08 PM   #6
Bored&Stroked
Couple gallons of anti-freeze
Old 05-14-2022, 10:11 PM   #7
fordor41
fordor41's Avatar
Ass't nuts and bolts, mechanics wire, elect. tape, length of wire as long as the vehicle, spare fuel filter, wire ties, fuses if used. Check truck over and think,"what could go wrong" , it probably will!
fordor41 is offline   Reply With Quote
Old 05-14-2022, 10:39 PM   #8
miwi
miwi's Avatar
Thanks guys
Old 05-14-2022, 10:50 PM   #9
deuce_roadster
deuce_roadster's Avatar
Instead of carrying ignition parts, carry a spare distributor already set up. Same with the spare fuel pump. But as stated, you are only going 1500 miles, shouldn't have to worry about much if the car was put together correctly. Make sure your spare is inflated.
Old 05-15-2022, 06:16 AM   #10
TJ
TJ's Avatar
Mike mentions a spare tire and I didn't not see it on your list. Definitely a necessary item.
Old 05-15-2022, 06:31 AM   #11
36coupe
36coupe's Avatar
I don’t always carry booster cables anymore but i do have my booster pack with me no matter what vehicle I have
36coupe is offline   Reply With Quote
Old 05-15-2022, 07:03 AM   #12
Veeder
A bible lol have a blast don’t stress to many potential issues just have a great ride
Veeder is offline   Reply With Quote
Old 05-15-2022, 07:54 AM   #13
Bored&Stroked
A WAD of cash . . . it can solve most problems! LOL
Old 05-15-2022, 10:41 AM   #14
blucar
blucar's Avatar
I am a firm believer of preventative maintenance. If the vehicle in question is in good shape, well maintained, the only parts I would consider would be a good spare tire, one that is equal to the tires on the ground. A spare generator, and fan belt, extra fuel pump and/or an electric pump plumbed and wired into the system.
I have driven my '36 Ford coupe w/59 AB engine over 94 K miles in the 71 years I have owned it, I have driven twice between Southern California and Eastern Idaho, a distance of 2,100 miles round trip, which was done none stop, seventeen hours each way, never a problem.. The only problem I have ever had with my Ford is a failed fuel pump, which I eliminated by installing an electric fuel pump.
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 05-15-2022, 10:49 AM   #15
drolston
drolston's Avatar
I carry a distributor that has been all set up and test driven. Minus the cap - but also carry a spare cap.
I can't believe everybody forgot one of the most common problems on a long trip. = Fuel filter.
Old 05-15-2022, 11:23 AM   #16
Willit Stop
Willit Stop's Avatar
Tow rope?
Willit Stop is online now   Reply With Quote
Old 05-15-2022, 11:26 AM   #17
J Franklin
J Franklin's Avatar
Originally Posted by Willit Stop View Post
Tow rope?
If he can tour those countries he can afford a roll-back ride if the wost happens.
Old 05-15-2022, 09:58 PM   #18
fordor41
fordor41's Avatar
Old 05-15-2022, 11:58 AM   #19
ford38v8
ford38v8's Avatar
No matter where in the world you travel, don't leave home without your Early Ford V8 Club Roster. You've got friends.
Alan
Old 05-15-2022, 12:41 PM   #20
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Check with each country to see what they require you to have in order to travel through them. A tire pump, tire patches, extra tire tube. A laptop to take with you.
File Type: jpeg EE4BC0AF-5F70-4119-9B9A-E7BDA757DF26_1_105_c.jpeg (13.9 KB, 38 views)
Old Redneck is offline   Reply With Quote
